0 Replies Latest reply on Jul 17, 2008 5:14 AM by Quester99
    Drag and Drop - Drag Image
      I'm using the Flex DragManager in an AdvancedDataGrid with HierarchicalData to allow the user to drag and drop tree nodes to re-order them. It is working fine. The problem I am having is with the drag image. The drag image does not always show up. It seems like it will appear for one drag and drop. Then if I try to drag another tree node I do not get the drag image there is just a line to show I'm dragging something.
      When I say drag image I mean the faded image of the text of the tree node which appears as I drag the tree node.
      I am using the following properties on the AdvancedDataGrid to enable drag and drop:
      dragEnabled="true" dropEnabled="true" dragMoveEnabled="true"
      Now if set dragMoveEnabled="false" then I do get a drag image everytime. But I need move the tree nodes around not copy them so I need dragMoveEnabled="true".
      Thank you
