7 Replies Latest reply on Nov 16, 2009 7:02 AM by the_wine_snob
    Burning DVD process stops
      When I tried to burn DVD with menu , burning process stop after rendering. When I remove menu and burn" play all" disk ,process ending
      successfully. My project contain 1 hour and 7 minutes video with titles , narration and music.I have Core 2 duo processor 3.0 GHz
      which during freezing is still working in 50% his capability and I have 4 GB RAM using in this time 75% capability (running 32 bit home
      premium Vista with 3,5 GB effective RAM memory.
      Can somebody explain this ?
        • 1. Re: Burning DVD process stops
          the_wine_snob Level 9
          First, a couple of questions:
          1.) What version of PrE are you using?
          2.) Which Menu set are you using?
          3.) Did you modify the Menu(s) in Photoshop/PSElements?
          4.) Do you have Chapter Markers, and a Scene Selection Menu, or just a Main Menu?
          5.) If you have Chapter Markers, can you describe exactly how they are set up?
          6.) Does the Disc layout Preview properly?
          7.) Are there any error messages, in either dialog screens, on in the lower section of the PrE GUI? If so, what are they?
          8.) What type of blank disc are you using?
          9.) What brand of blank disc are you using?
          • 2. Re: Burning DVD process stops
            tedpiet@comcast.net Level 1
            Thank You for very quick respond. I try to answer on Your question as correct as I can.
            1.Premiere Element 4.0
            2.Menu from program templates from travel section
            4Main Menu +1scene menu with 7 scenes
            5I have scene marks and they set-up as scene mark
            9TAIYO YUDEN
            Some update: few days ago I was able to burn 3 disks with menu. This time in the burn screen , rendering process running O.K. and when
            program go to burn disk I si progres bar start to be blue and stop aftermoment. Do not see any message.
            • 3. Re: Burning DVD process stops
              Thanks for the info.
              Since you have burned other DVD's, and Taiyo Yuden are about as good as it gets (Verbatim is also great), that pretty much takes the blank media out of the mix.
              The general layout of the Project sounds good, and I have not heard of any issues with the Travel Templates. Which ones in particular?
              Now, if you can post a screen-cap of the Timeline with those Chapter Markers, there might be something there. There is about only one thing that I can think of, and that is a Stop Marker out of place, or similar. As most of the Scene Selection Menus are 2 x 2 (total of 4 Scenes) per Sub-Menu, you should have one Main Menu and then two Scene Selection Menus. If all works in Preview, there is probably not an issue with the Chapter Markers, but maybe someone can spot something in the screen-caps.
              Right now, I am at a total loss, and you have helped rule out about everything that would commonly cause issues.
              • 4. Re: Burning DVD process stops
                Are you able to burn to a folder on your hard drive rather than directly to a disc?
                • 5. Re: Burning DVD process stops
                  Hunt And Steve
                  Thank You both for respond. To continue find problem I try to burn project to folder instead of disk.Result was same , burn stops after
                  rendering stage. Here is screen shot #2
                  In next step I also removed stop marker - result is same
                  I ben using "road trip" menu from travel menu section of templates , and I positioned main menu on very beginning of the project , then 7 scene menus on beginning of each scene and also stop marker on the end of project. Screen shot #1 showing menu screenttScreen Shot12.jpgPlease advice me what should I take as next step to resolve this issueScreen Shot.jpg
                  • 6. Re: Burning DVD process stops
                    I think it's time to close this thread. Problem is resolved , but I don't know this happen. I performed this steps
                    1.I have several projects residing in Adobe folder. Some of them I was able to burn to DVD with menu , however
                       when problem with burning start , none of this projects could be burn to DVD with menu. while burning DVD
                       with out menu was successful for all projects. I also notice that program was running very slow.
                    2.Uninstall and perform clean installation PE4
                    3.Placed in project scene markers only and somehow main menu page was created automatically by program.
                      After this , burning DVD with menu didn't create any problem
                    I would like to know if somebody have explanation for this behaving
                    • 7. Re: Burning DVD process stops
                      Glad that you are now able to Burn to Disc.
                      It could be that the installation had become corrupt for some reason, or that the Scene Markers in some of the Projects were not set correctly, and PrE 4 was unable to add the Menus per those marker, or a combo of the two. Of course, that does not rule out something completely different.
                      We may never know, but your being able to burn is great news and thank you for reporting.
