1 Reply Latest reply on Nov 8, 2009 7:35 PM by JimHess-hfHwAH
    Application could not load Adobe Camera Raw
    cfbga Level 1
      After a clean install of Windows XP I had to reload all my adobe applications (Photoshop CS2,  Bridge CS2, After Effects and Encore 1.5).  Now when I open Bridge I receive  "The application could not load Adobe Camera Raw. Use the Adobe Bridge Installer to reinstall the Adobe Camera Raw plug-in.  If you continue you may experience some probelms when attempting to modify raw image files."
      Is the current Camera Raw 5.5 compatible with Photoshop CS2?  If so how do I install the download?
      Any help would be greatly appreciated.
      Carolyn
        • 1. Re: Application could not load Adobe Camera Raw
          JimHess-hfHwAH
          The last version of Camera Raw compatible with Photoshop CS2 is Camera Raw 3.7.  Download that version and install it properly, and everything should work.  If your camera is not supported by that version then download the latest version of the DNG converter to convert your raw images to DNG.  Then you can open those files in Photoshop CS2/ACR 3.7.
