13 Replies Latest reply on Sep 12, 2010 7:12 PM by 80sradio
    Gradient fill will not change angle.
    80sradio Level 1
      Hello all.  I have designed a shoe in Adobe Illustrator CS4.  As you can see, the fill works successfully.  However as you can also see in the box, the angle is set to 45 degrees, as noted in the red ring.
      Note how the angle in the shoe graphic is still set at 0 degrees.  Does anyone know why I can not change the angle of the gradient
      I am using the live paint brush to splash the gradient into the area.
      Mark
