3 Replies Latest reply on Nov 9, 2009 8:51 AM by AdobeScripts
    Disable Preview mode in CS2
    Peter Bossens Level 1
      How can I desactivate the preview mode (shortcut W) in InDesign CS2 using Applescript (or Javascript)?
      In CS3 & CS4 the command is "set view display setting to typical", but this does not work in CS2.
      Peter Bossens
        • 1. Re: Disable Preview mode in CS2
          AdobeScripts Level 3
          hi Peter,
          if you are talking about DisplayPerformancePreference:
          Class DisplayPerformancePreference
              Member of InDesign
              Application's default display performance settings
          then nothing was changed - CS2 work the same way like CS3 and CS4
          but if you are talking about EnableRedraw
          Property EnableRedraw As Boolean
              Member of InDesign.ScriptPreference
              If true, enables redraw during script execution
          then it was introduced in CS3
          robin
          www.adobescripts.co.uk
          • 2. Re: Disable Preview mode in CS2
            Robert,
            Sorry I was not quite clear. I mean the view that shows the page like it will be printed, without frame edges, bleed, ....
            The command for desactivating the Preview mode in CS3/CS4 is:
            Set the screen mode to preview off
            But I can't find the equivalent for this command in CS2, although the Preview mode exists in the user interface.
            Peter
            • 3. Re: Disable Preview mode in CS2
              I'm sorry Peter, but I'm not AppleScript man
              robin
