7 Replies Latest reply on May 3, 2010 11:33 AM by Jason San Jose
    file > export > release build + nothing happens.
    nikos101 Level 2
      I have an important Flex MXML application that when I go to file > export > release build and nothing happens.
      Any ideas where I go from here?
      Clean has no effect.
        • 1. Re: file > export > release build + nothing happens.
          pwp69 Level 1
          I am experiencing something similiar.  Did you
          figure out the problem?
          • 2. Re: file > export > release build + nothing happens.
            David_F57 Level 5
            Have you tried to do it through the project menu ?  -- just a thought.
            David.
            [edit] - Also try deleting the bin-release folder for the project (if it exists).
            • 3. Re: file > export > release build + nothing happens.
              ria-coder Level 1
              Experiencing the same issue!! Nothing makes it work... Incredibly frustrating... Surely this was something that Adobe would test before releasing?
              • 4. Re: file > export > release build + nothing happens.
                ria-coder Level 1
                Here's the error i'm getting from the Eclipse error log... WTF?! I'm not making an iPhone project!!!
                java.lang.NoClassDefFoundError: com/adobe/flexbuilder/project/air/IIPhoneProject
                at com.adobe.flexbuilder.exportimport.releaseversion.ui.ExportReleaseVersionProjectAndLocati onPage.isIPhoneProjectSelected(ExportReleaseVersionProjectAndLocationPage.java:1107)
                at com.adobe.flexbuilder.exportimport.releaseversion.ui.ExportReleaseVersionProjectAndLocati onPage.getDefaultLocation(ExportReleaseVersionProjectAndLocationPage.java:1002)
                at com.adobe.flexbuilder.exportimport.releaseversion.ui.ExportReleaseVersionProjectAndLocati onPage.loadSettings(ExportReleaseVersionProjectAndLocationPage.java:965)
                at com.adobe.flexbuilder.exportimport.releaseversion.ui.ExportReleaseVersionProjectAndLocati onPage.createControl(ExportReleaseVersionProjectAndLocationPage.java:730)
                at org.eclipse.jface.wizard.Wizard.createPageControls(Wizard.java:170)
                at com.adobe.flexbuilder.exportimport.releaseversion.ui.ExportReleaseVersionWizard.createPag eControls(ExportReleaseVersionWizard.java:585)
                at org.eclipse.jface.wizard.WizardDialog.createPageControls(WizardDialog.java:675)
                at org.eclipse.jface.wizard.WizardDialog.createContents(WizardDialog.java:549)
                at org.eclipse.jface.window.Window.create(Window.java:431)
                at org.eclipse.jface.dialogs.Dialog.create(Dialog.java:1089)
                at com.adobe.flexbuilder.exportimport.releaseversion.ExportReleaseVersionAction$1.run(Export ReleaseVersionAction.java:93)
                at com.adobe.flexbuilder.exportimport.releaseversion.ExportReleaseVersionAction.run(ExportRe leaseVersionAction.java:103)
                at org.eclipse.ui.internal.PluginAction.runWithEvent(PluginAction.java:251)
                at org.eclipse.ui.internal.WWinPluginAction.runWithEvent(WWinPluginAction.java:229)
                at org.eclipse.jface.action.ActionContributionItem.handleWidgetSelection(ActionContributionI tem.java:584)
                at org.eclipse.jface.action.ActionContributionItem.access$2(ActionContributionItem.java:501)
                at org.eclipse.jface.action.ActionContributionItem$6.handleEvent(ActionContributionItem.java :452)
                at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java:84)
                at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1003)
                at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:3910)
                at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3503)
                at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.java:2405)
                at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2369)
                at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:2221)
                at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:500)
                at org.eclipse.core.databinding.observable.Realm.runWithDefault(Realm.java:332)
                at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:493)
                at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.java:149)
                at org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:113)
                at org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:194)
                at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLau ncher.java:110)
                at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.jav a:79)
                at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:368)
                at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:179)
                at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
                at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
                at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
                at java.lang.reflect.Method.invoke(Unknown Source)
                at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:559)
                at org.eclipse.equinox.launcher.Main.basicRun(Main.java:514)
                at org.eclipse.equinox.launcher.Main.run(Main.java:1311)
                • 5. Re: file > export > release build + nothing happens.
                  nikos101 Level 2
                  you need to make a new project and bring in the files
                  • 6. Re: file > export > release build + nothing happens.
                    SrinivasAnnam Adobe Employee
                    Could you please let us know below details so that we can look in to this issue:
                        1. Version of Flash Builder along with build number
                        2. Type of Flash Builder - StandAlone or Plug-in ?
                        3. Installation Type - Updater or Full installer ?
                        4. Operation System - WinXP / Win vista / Win 7 / Mac OS 10.6 etc...
                    Srinivas Annam
                    • 7. Re: file > export > release build + nothing happens.
                      Jason San Jose Adobe Employee
                      ria-coder, I believe you've posted to the wrong forum. Please post your issue on the Adobe Prerelease forum.
                      Jason San Jose
                      Software Engineer, Flash Builder
