4 Replies Latest reply on Nov 9, 2009 4:38 PM by pguerett
    How to pass WSDL URL to Webservice:Invoke Web Service in workflow
    g5spark Newcomer
      REPOSTED IN LiveCycle Workbench ES
      I have a workflow with 1 step, WebService:Invoke Web Service.  I'd like to be able to pass a string parameter of the end point url to the WSDL URL parameter in the WebService Setting dialogue box as oppose to passing the actual url (http://machine/some_service.svc?wsdl).
      The reason is as we migrate the workflow between environments DEV, TEST, etc, we don't want to have to reopen the workflow in each env and update the DEV, TEST end point.
      I  tried the following with no success
      1.       Create a parameter devURL of type String
      2.       By default, set the value to http://machine/some_service.svc?wsdl
      3.       Goto the web service call step and set the WSDL URL to the /process_data/@devURL
      I get the error:
      java.io.FileNotFoundException: \process_data\@devURL
              at org.jboss.net.protocol.file.FileURLConnection.connect(FileURLConnection.java:94)
              at org.jboss.net.protocol.file.FileURLConnection.getInputStream(FileURLConnection.java:103)
              at org.apache.xerces.impl.XMLEntityManager.setupCurrentEntity(Unknown Source)
              at org.apache.xerces.impl.XMLVersionDetector.determineDocVersion(Unknown Source)
              at org.apache.xerces.parsers.XML11Configuration.parse(Unknown Source)
              at org.apache.xerces.parsers.XMLParser.parse(Unknown Source)
              at org.apache.xerces.parsers.DOMParser.parse(Unknown Source)
              at org.apache.xerces.jaxp.DocumentBuilderImpl.parse(Unknown Source)
              at org.apache.axis.utils.XMLUtils.newDocument(XMLUtils.java:369)
              at org.apache.axis.utils.XMLUtils.newDocument(XMLUtils.java:420)
              at org.apache.axis.wsdl.symbolTable.SymbolTable.populate(SymbolTable.java:482)
              at org.apache.axis.wsdl.gen.Parser$WSDLRunnable.run(Parser.java:361)
              at java.lang.Thread.run(Thread.java:595)
      I don't believe the WSDL URL parameter can even accept a parameter like the User Name + Password parameters.
      Is this possible?  OR how else can this be achieved?
