6 Replies Latest reply on Nov 9, 2009 3:49 PM by Chet Haase
    Transitioning a corner radius?
    Handycam Level 1
      In the component I mentioned earlier, I was going to have a Rect the size of the component as the background.  When in the Normal state, I want almost no corner rounding, but in the over state I do.  This code works fine, but the radius "jumps", and the drop shadow is of the non-rounded Rect...
      <s:SkinnableContainer xmlns:fx="http://ns.adobe.com/mxml/2009"
                            xmlns:mx="library://ns.adobe.com/flex/halo" rollOver="currentState='over'" rollOut="currentState='normal'"
                            width.normal="40" height.normal="40" width.over="200" height.over="200">
           <s:states>
                <s:State name="normal"/>
                <s:State name="over" />
           </s:states>
           <s:transitions>
                <s:Transition fromState="normal" toState="over" autoReverse="true">
                  <s:Sequence>
                    <s:Resize duration="500" target="{this}"/>
                    <s:Fade duration="100" target="{mainContents}" alphaFrom="0" alphaTo="1"/>
                  </s:Sequence>
                </s:Transition>
                <s:Transition fromState="over" toState="normal" autoReverse="true">
                   <s:Sequence>
                      <s:Fade duration="100" target="{mainContents}" alphaFrom="1" alphaTo="0"/>
                   </s:Sequence>
                </s:Transition>
           </s:transitions>
           <!-- main background -->
           <s:Rect id="bg" top="0" left="0" bottom="0" right="0" radiusX.normal="1" radiusX.over="12">
                <s:filters>
                   <s:DropShadowFilter angle="45" distance="5" blurX="10" blurY="10" alpha=".3"/>
                </s:filters>
                <s:fill>
                   <s:SolidColor color="#ccff00"/>
                </s:fill>
           </s:Rect>
           <s:Group id="mainContents" top="10" left="10" bottom="10" right="10" includeIn="over">
                <s:Label text="FOO"/>
           </s:Group>
      </s:SkinnableContainer>
        • 1. Re: Transitioning a corner radius?
          Handycam Level 1
          Similarly, how do you transition a filter property:
          <s:DropShadowFilter angle="45" distance.normal="2" alpha.normal=".3" distance.over="4" alpha.over=".5" blurX="10" blurY="10"/>
          • 2. Re: Transitioning a corner radius?
            Shongrunden Adobe Employee
            You could use an Animate effect with a couple SimpleMotionPaths:
            <s:transitions>
                            <s:Sequence>
                                <s:Animate duration="500" target="{bg}">
                                    <s:SimpleMotionPath property="radiusX" />
                                    <s:SimpleMotionPath property="radiusY" />
                                </s:Animate>
                            </s:Sequence>
                        </s:Transition>
                            <s:Sequence>
                                <s:Resize duration="500" target="{this}" />
                                </s:Animate>
                            </s:Sequence>
                        </s:Transition>
            </s:transitions>
            • 3. Re: Transitioning a corner radius?
              You can use a SimpleMotionPath to animate the properties on the the filter too.  Put an id on your filter then use an Animate like this:
              <s:Animate target="{myDropShadowFilter}">
                  <s:SimpleMotionPath property="distance" />
                  <s:SimpleMotionPath property="alpha" />
              </s:Animate>
              • 4. Re: Transitioning a corner radius?
                Handycam Level 1
                That is truly outstanding!  Many thanks!!
                How do you transition a color?
                When I try what I expected:
                <s:Animate duration="300" target="{bgFill}">
                  <s:SimpleMotionPath property="color" />
                </s:Animate>
                It animates, but through the hues.  In other words, a red Rect goes through pink and other colors before reaching pale yellow...
                <s:SolidColor id="bgFill" color.normal="#FF0000" color.over="#F7F9DF"/>
                • 6. Re: Transitioning a corner radius?
                  Chet Haase Level 3
                  Use AnimateColor. Here's a quick tutorial:
                  http://graphics-geek.blogspot.com/2009/08/video-animatecolor-in-flex-4.html
                  There's a bunch of other videos/tutorials on Flex 4 effect usage on that blog; you might want to check them out if you're starting to play with them or looking for the Big Picture on how things work.
                  Chet.
