0 Replies Latest reply on Nov 9, 2009 4:26 PM by jeremy.banks
    UTF-16 Encoding
    jeremy.banks
      Hi
      I have a web service that a flex app connects to.  I'm trying to change the service to use UTF-16 encoding, but I'm struggling to get Flex to successfully read the data returned.
      Some simplified code:
            private function _loginReturned(event:Event):void
               var request:URLRequest = new URLRequest(_restUrl + "user");
               var stream:URLStream = new URLStream();
               stream.addEventListener(Event.COMPLETE, _streamReturned);
               stream.load(request);
            private function _streamReturned(event:Event):void
               var stream:URLStream = (event.target as URLStream);
               trace("stream: " + stream.readMultiByte(stream.bytesAvailable, "unicode"));
      This traces "stream: "
      If I change _streamReturned to:
               while (0 < stream.bytesAvailable)
                  trace("stream: " + stream.readMultiByte(1, "unicode"));
      Then I get a trace of:
      stream:
      stream: <
      stream:
      stream: ?
      stream:
      stream: x
      stream:
      stream: m
      stream:
      stream: l
      stream:
      stream:
      stream:
      stream: v
      stream:
      stream: e
      stream:
      stream: r
      stream:
      stream: s
      stream:
      stream: i
      stream:
      stream: o
      Indicating that every character is being encoded within two bytes, which is about what I'd expect.
      Any ideas why stream.readMultiByte(stream.bytesAvailable, "unicode") doesn't return anything useful?
      The backend is set to encode using UTF-16BE, but I have tried it with UTF-16 and UTF-16LE as well with no luck.  I also tried using unicodeFFFE in the readMultiByte call but also with no luck.
      Thanks in advance for your help.
      Jeremy
