4 Replies Latest reply on Nov 12, 2009 2:32 AM by Dooza (Steve)
    Set default optimise settings
    Dooza (Steve) Level 2
      Hi there,
      Hope your all doing fine, its been a long time since I posted, but needs must
      I am looking for a way to change the default optimise settings, from GIF to JPG. Is there a way to do this? I am using CS3.
      Cheers,
      Dooza
        • 1. Re: Set default optimise settings
          pixlor Level 4
          I have CS3 and I use the Image Preview feature. Every time I go to export an image that way, I am presented with the settings I used the last time.
          • 2. Re: Set default optimise settings
            Hi Pixlor,
            When you say it was the last settings you used, is that on the same image, or a brand new image?
            Dooza
            • 3. Re: Set default optimise settings
              pixlor Level 4
              That's for a brand new image.
              I often make screen captures and save them as PNG24, and that's what's waiting for me whenever I make a new image. It's also the image format I get when I make a slice, simply because it's the last format I exported to.
              I agree with you, though. I wish there were a way to set/override a default, rather than depend on "what you did last," because that just isn't very reliable.
              • 4. Re: Set default optimise settings
                To be honest I never use the image preview, but if its the way to have my last selection remembered then I will start using it.
                I think I will make a wish, see if the Export option can actually have the optimise settings available, so if you haven't changed it to the correct one, you don't have to cancel out of export, then change it, and then back to export. I will also wish for a default optimise setting, so you can create your own, and have that as the default. If enough people wish for the same, or similar, then it might just happen.
                Cheers,
                Dooza
