0 Replies Latest reply on Nov 10, 2009 5:14 AM by rock_life
    Tabbing issue for readonly fields
    rock_life
      Hi im new to javascripting for adobe forms .
      Kindly help me with the below issue that im facing in the adobe formss with reverse tabbing,
      the reverse tabbing is not working for the following scenarion.
      I have created drop down box (say d1) in which when for certain values it would make a text box(say T1) as readonly,
      but after selecting a value from the drop down and on tabbing the focus goes on to the text box field that has a property of readonly which should not be case as it must go on to the next field (N1)
      I tried setting the focus to get shifted to the next required field but this fails when i do a reverse tab order
      as a reverse tab order takes makes the focus shift to this field (N1) instead of the field previous to drop down box
      urgent help required on this
      Thank you
