3 Replies Latest reply on Nov 10, 2009 12:09 PM by kglad
    FLV source
    PakoCancun
      Hi
      I'm making a flash document and in one of the frames I wanna play a .f4v video
      I inserted a player component and in the source parameter I put the location of the video (where it is rightnow)
      but the thing is I wanna publish that document into SWF and burn it into a CD for distribution and I don't know
      what to put on the source parameter of the player component so it will play the video that I will add to the CD
      I don't want to embed the video because I'm worried about the size of the document I hope someone can help
      Source Now --->   /User/documents..../video.f4v
      P.S.: USING FLASH CS4 AND AS 3.0 IF IT HELPS
        • 1. Re: FLV source
          use a relative path to your video.  so, for example, if your video is in the f4v subdirectory of the directory that contains your html and swf files, use:
          "f4v/video.f4v"
          as the source.
          • 2. Re: FLV source
            PakoCancun Level 1
            Hey thanks
            but I tried what u said and it won't play anything
            and you also said something about an html file
            I don't have one do I need to have one?
            (sorry kind of new with flash)
            • 3. Re: FLV source
              if everything was working when you used an absolute path and then failed when you used a relative path, your path or file name (or both) are incorrect.
              and no, you don't need an html file.
