2 Replies Latest reply on Nov 12, 2009 3:46 AM by littlebridge
    RemoteObject arrays allocates same memory
    littlebridge
      When I receive remote data, if the arrays are identical it allocated the same storage to the two arrays:
      I have a AS3 remote object eg:
      Snippet:
          [RemoteClass(alias="TestVO")]
          public class TestVO
                public var test1:Array;
                public var test2:Array;
      When I receive remote data, if the array data are identical it allocated the same storage to the two arrays.
      Eg: From remote server (PHP / ZendAMF) I send:
      $this->test1 = array("foo", "bar");
      $this->test2 = array("foo", "bar");
      When I debug the TestVO object in Flex debugger I get (for example):
      test1     Array(@597d779)
      test2     Array(@597d779)
      ie: they reference the same memory, which obviously causes problems.
      If I send from remote server slightly different values:
      $this->test2 = array("bar", "foo");
      In the Flex debugger I get two arrays as you'd expect:
      test1     Array(@54cb7e9)
      test2     Array(@54cb741)
      Remote object mappings work all Ok, just it seems arrays with duplicate data.  I haven't yet tried 2 objects with identical property values...
      Anyone know why this is?
      Thanks.
