3 Replies Latest reply on Nov 11, 2009 12:48 PM by salem_b_a
    How to fill an Array with results from a CallResponder?
    petousas
      I want to fill an Array with the resuls of my data servic(witch returns an array with objects)
      <s:CallResponder id="getRatesBetweenByIdResult"/>
      <ratescontroller:RatesController id="ratesController" fault="Alert.show(event.fault.faultString + '\n' + event.fault.faultDetail)" showBusyCursor="true"/>
      I have succesfully filled a datagrid specyfing
      getRatesBetweenByIdResult.token = ratesController.getRatesBetweenById(query);
      and
      <mx:DataGrid x="433" y="258" id="dataGrid"  dataProvider="{getRatesBetweenByIdResult.lastResult}">
      But after that is very difficult to get the actually data from dataGrid. I tryed this but didnt work
      var p:String = dataGrid.data[0].price; //where price one of my Datagrid Column
      Actually i don't need the dataGrid to appear in my design but is the only way i know to get data from my dataservices.
      Using Flash Builder 4beta2 with zend amf.
      Thanks for any hint or suggestion
        • 1. Re: How to fill an Array with results from a CallResponder?
          Subeesh Arakkan Level 4
          There is no need to use a DataGrid just for getting the array from the service. After you import the Webservice, create an instance of it .Set an ID, create result and fault handlers.Check this code snippet ( GlobalWeather is the WebService I have used for testing).
          <fx:Declarations>
               <globalweather:Globalweather id="service" result="service_resultHandler(event)"
                                                        fault="service_faultHandler(event)"/>
          </fx:Declarations>
          Invoke the service the service. ( GetWeather is a valid method in the service )
          service.GetWeather("India");
          Put a break point in the result Handler and you will find the array in the event.result object
          protected function service_resultHandler(event:ResultEvent):void
               // Result array will be in event.result
          • 2. Re: How to fill an Array with results from a CallResponder?
            petousas Level 1
            thanks for the hint.It works if my services returns one result.But not works with many.
            I want to fill an Array with the resuls of my data service(witch returns an array with MANY objects)
            The event.result has my array of objects BUT typecasted as OBJECT and i can't access all the values .
            The API says:
            mx.rpc.events.ResultEvent.result():Object
            [Read Only] Result that the RPC call returns.
            Also the compiler don't let me to  hard typecast an object to Array
            thanks for any help
            • 3. Re: How to fill an Array with results from a CallResponder?
              salem_b_a
              hi,
              try this
              when handling the result,
              var aux:Array = new Array(event.result[0]);
              if this post helped, please mark
