2 Replies Latest reply on Nov 11, 2009 7:52 AM by benoismyname
    What's Wrong With This AS3?
    benoismyname
      Hi;
      I'm a noob to AS3 and I know this code couldn't possibly work because I don't call "Main". Please advise.
      import flash.display.MovieClip;
      import com.greensock.*;
      import com.greensock.plugins.*;
      import com.greensock.easing.*;
      TweenPlugin.activate([AutoAlphaPlugin]);
      public class Main extends MovieClip
      private var mcHatAndFace:MovieClip;
      public function Main():void
      mcHatAndFace = new LibraryItem();
      mcHatAndFace.x = 100;
      mcHatAndFace.y = 100;
      mcHatAndFace.alpha = 0;
      addChild(mcHatAndFace);
      TweenLite.to(mcHatAndFace, 1, {autoAlpha:1}); // 2nd param in seconds; 3rd in % alpha
      TIA,
      beno
        • 1. Re: What's Wrong With This AS3?
          do you want to make Main your document class?  if so, click on the stage and in the properties panel you'll see a textfield where you can enter the document class.  type Main
          • 2. Re: What's Wrong With This AS3?
            benoismyname Level 1
            When I went to enter that and create a swf, it stated that the document class couldn't be found and would be created. Despite the fact that I canceled out of it, then closed the fla without saving, it *still* saved that change! At any rate, the swf didn't play. I thought perhaps I should add to the script, which is on the first frame of its own layer, a gotoAndPlay(Main). At any rate, nothing's working. Please advise.
            TIA,
            beno
            gotoAndPlay(Main);
