0 Replies Latest reply on Nov 10, 2009 8:02 PM by roshni79
    Renaming  index.template.html to jsp file
    roshni79 Level 1
      Hello all,
      By referring http://www.morearty.com/blog/2006/12/11/changing-the-filenames-in-flex-builder-html-templa tes/
      I renamed index.template.html of my flex project to ${application}${build_suffix}.template.jsp.
      On building project, I could find myAppMainFile.jsp in folder bin-debug.
      But when I run project in debug mode from flex builder IDE, I am getting an error
      File not found: C:\Documents and Settings\myDomain\My Documents\Flex Builder 3\myProject\bin-debug\ myAppMainFile.html
      I tried by changing URL or path to change fields of Run/Debug settings of Project properties. Now the application launch takes a couple of minutes and times out with message
      Failed to connect; session timed out.Ensure that:
        1. You compiled your Flash application with debugging on.
        2. You are running the debugger version of Flash Player.
      Somebody please help
      Thanks.
      roshni
