8 Replies Latest reply on Nov 12, 2009 12:08 AM by al7iss
    Dynamically generating Buttons
    al7iss
      Hi, I'm trying to generate dynamically 10 linkbuttons in flex, it works but when I add a mouse click event listener, i can't get the clicked button label.
      Actually, i stored the labels in an array but when i try to access array [ j ] in the event handler j is always 10 (where it should be beween 0 and 9).
      here is my code:
      <?xml version="1.0"?>
      <mx:Application xmlns:mx="" applicationComplete="init();">
          <mx:Script>
             <![CDATA[
                  public var listaddbutton:Array=new Array();
                  public var array:Array
                  public function init():void{
                  var xx:int=40;
                  a=new Array();
                  for(var j:uint = 0; j < 10; j++){
                      listaddbutton.push(new LinkButton());
                      listaddbutton[j].label="linkButton "+j;
                      array.push(listaddbutton[j].label);
                      listaddbutton[j].addEventListener(MouseEvent.CLICK,f);
                             function f(e:MouseEvent):void{
                                Alert.show(array[j]);
            listaddbutton[j].x=xx
            p.addChild(listaddbutton[j]);
            xx+=60;
          </mx:Script>
          <mx:Canvas width="444" height="348" id="p">
          </mx:Canvas>
      </mx:Application>
      Please help, thanks
        • 1. Re: Dynamically generating Buttons
          al7iss Level 1
          I know I maybe wasn't very clear in my post so please tell me what you don't understand so I will try to clarify it.
          I'm stuck with this for two days now.
          • 2. Re: Dynamically generating Buttons
            blaka zakata Level 1
            No, it shouldn't
            I don't know why you use the array of labels. You could get button label in event listener:
            var lb:LinkButton = event.target as LinkButton;
            var label:String = lb.label;
            To store some data you could use the data property of LinkButton:
            var lb:LinkButton...
            // store data
            lb.data = {"somenumber": Number(567), "somestring": "765"};
            // get data
            var n:Number = lb.data["somenumber"];
            all-in-one example
            • 3. Re: Dynamically generating Buttons
              susrut316
              Try the code below...may be this would solve your purpose.
              <mx:Application xmlns:mx="http://www.adobe.com/2006/mxml" layout="absolute"
                  creationComplete="init()">
                  <mx:Script>
                      <![CDATA[
                          import mx.controls.Alert;
                          import mx.controls.LinkButton;
                          private var listAddBtn:Array = [];
                          private function init():void
                              var xx:int = 0;
                              for(var j:int=0; j<10; j++)
                                  var lBtn:LinkButton = new LinkButton();
                                  lBtn.label = "linkButton" + j;
                                  listAddBtn.push(lBtn.label);
                                  lBtn.addEventListener(MouseEvent.CLICK, onButtonClick);
                                  lBtn.x = xx;
                                  cnv.addChild(lBtn);
                                  xx += 80;
                          private function onButtonClick(event:MouseEvent):void
                              Alert.show('Clicked Button: '+event.currentTarget.label +'\n Button Array: [' + listAddBtn + ']');
                  </mx:Script>
                  <mx:Canvas id="cnv" width="444" height="348"/>
              </mx:Application>
              • 4. Re: Dynamically generating Buttons
                al7iss Level 1
                THANK YOU very much. It worked perfectly .
                • 5. Re: Dynamically generating Buttons
                  JAcques TRIPOZ
                  I don't really understand why you're using arrays, if you only wan't
                  to get the label (or get access to the button that is clicked) : just
                  get the event target and cast it as a LinkButton and then grab anything
                  you want...
                  Try this :
                      <mx:Script>
                          <![CDATA[
                                  var xx:int=40;
                                  var a:Array=new Array();
                                  for (var j:uint=0; j < 10; j++)
                                      var b:LinkButton=new LinkButton();
                                      b.label="linkButton " + j;
                                      b.addEventListener(MouseEvent.CLICK, f);
                                      b.x=xx;
                                      p.addChild(b);
                                      xx+=60;
                                  var b:LinkButton=e.target as LinkButton;
                                  Alert.show(b.label);
                      </mx:Script>
                                 height="348"
                                 id="p">
                      </mx:Canvas>
                  </mx:Application>
                  Actually, i stored the labels in an array but when i try to access array in the event handler j is always 10 (where it should be beween 0 and 9).
                  here is my code:
                      <mx:Script>
                         <![CDATA[
                              var xx:int=40;
                              a=new Array();
                        xx+=60;
                      </mx:Script>
                      </mx:Canvas>
                  </mx:Application>
                  Please help, thanks
                  • 6. Re: Dynamically generating Buttons
                    al7iss Level 1
                    your code worked perfectly but when I try to use the PopUpManager in the event handles it doesn't work and it works when i use only one button.
                    PopUp.mxml
                    <mx:Application xmlns:mx="http://www.adobe.com/2006/mxml" layout="absolute" creationComplete="appOnCreationComplete()">
                        <mx:Canvas id="p" left="10" top="10" right="10" bottom="10">
                        </mx:Canvas>
                        <mx:Script>
                              <![CDATA[
                                import mx.utils.StringUtil;
                                import mx.managers.PopUpManager;
                                public var listaddbutton:Array = new Array();
                                private function appOnCreationComplete():void {
                                      var yy:int = 10;
                                      for(var j:uint = 0; j < 10; j++) {
                                          listaddbutton[j].label = "linkButton " + j;
                                          listaddbutton[j].data = {"index": j,"i":j};
                                        listaddbutton[j].addEventListener(MouseEvent.CLICK, function(ev:MouseEvent):void {
                                      var win:MyCanvas = PopUpManager.createPopUp(this, MyCanvas, true) as MyCanvas;
                                      PopUpManager.centerPopUp(win);
                                        listaddbutton[j].y = yy;
                                        listaddbutton[j].x = 10;
                                        yy += 32;
                        </mx:Script>
                    </mx:Application>
                    MyCanvas.mxml
                    <mx:TitleWindow xmlns:mx="http://www.adobe.com/2006/mxml"
                            layout="vertical"
                            title="popup"
                            showCloseButton="true"
                            width="478"
                            height="394"
                            close="titleWindow_close(event);" backgroundColor="#171E43">
                        <mx:Script>
                            <![CDATA[
                                import mx.events.CloseEvent;
                                private function titleWindow_close(evt:CloseEvent):void {
                                    PopUpManager.removePopUp(this);
                        </mx:Script>
                        <mx:Canvas width="436" height="338" backgroundColor="#171E43">
                        </mx:Canvas>
                    </mx:TitleWindow>
                    • 7. Re: Dynamically generating Buttons
                      susrut316 Level 1
                      Try the code below.
                          </mx:Canvas>
                          <mx:Script>
                                <![CDATA[
                                    import mx.core.IFlexDisplayObject;
                                        var yy:int = 10;
                                            listaddbutton[j].addEventListener(MouseEvent.CLICK, onClick);
                                          yy += 32;
                                  private function onClick(ev:MouseEvent):void
                          </mx:Script>
                      </mx:Application>
                      • 8. Re: Dynamically generating Buttons
                        al7iss Level 1
                        Thanks, it works
