5 Replies Latest reply on Nov 12, 2009 3:35 AM by Harbs.
    [JS CS3] Touching Objects
    Stefan Huwiler
      Hi
      Is there a way to obtain all objects who are touching a certain frame on a page?
      Thanks for answers
      Stefan Huwiler
        • 1. Re: [JS CS3] Touching Objects
          franzi_ska
          if the objects are rectengular, you could try to compare the geometric bounds of the objects with the frame.
          Regards,
          Franziska
          • 2. Re: [JS CS3] Touching Objects
            That's the easy case -- see below. "Touching" is a bit .. touchy. If you place two rectangles side-by-side on the same guideline, this script will not always sense the touch. Perhaps the positions differ in the 4th decimal.
            However, giving a little leeway in the "touches" function below is not a problem (deciding how much is).
            This script deselects your current selection and instead selects all objects that "touch" it.
            frame = app.selection[0];
            frame.select (SelectionOptions.REMOVE_FROM);
            page = frame.parent;
            if (!(page instanceof Page))
             alert ("That's not on a page..");
             exit();
            for (allitems = 0; allitems<page.pageItems.length; allitems++)
             if (frame != page.pageItems[allitems] && touches (frame.geometricBounds, page.pageItems[allitems].geometricBounds))
              page.pageItems[allitems].select (SelectionOptions.ADD_TO);
            // geometricBounds: [ty lx by rx]
            function touches(bounds1, bounds2)
             if (bounds1[2] < bounds2[0]) return false;
             if (bounds1[0] > bounds2[2]) return false;
             if (bounds1[1] > bounds2[3]) return false;
             if (bounds1[3] < bounds2[1]) return false;
             return true;
            • 3. Re: [JS CS3] Touching Objects
              Stefan Huwiler Level 1
              I was thinking about such a way too, but was interested if there is maybe another way.
              I thought InDesign internally knows what objects are overlapping or upon another.
              Thanks für the answers.
              • 4. Re: [JS CS3] Touching Objects
                Marc Autret Level 4
                It's not so simple. The 'bounds' property deals with bounding box disregarding the inner path of the object (polygons, ovals, rotated or sheared frames).
                1) If 2 bounding box have no intersection, you are sure that the 2 underlying objects don't intersect.
                but
                2) If 2 bounding box intersect, you are not sure that the 2 underlying objects intersect.
                In a recent project I had to check for touching polygons.
                The 'bounds' approach provides a quick diagnostic when the conclusion is "no intersection":
                /*bool*/ Polygon.prototype.collideBounds = function(/*Polygon*/ _poly)
                // Ret. TRUE if the bounding boxes intersect, else return FALSE
                // quick method, but TRUE does not mean the shapes actually intersect
                var b = this.visibleBounds;
                var _b = _poly.visibleBounds;
                return( !((b[0]>_b[2]) || (b[2]<_b[0]) || (b[1]>_b[3]) || (b[3]<_b[1])) );
                When p1.collideBounds(p2) is TRUE, I need to invoke another method to refine the test. Then I use the intersectPath method, which is dramatically slower:
                /*bool*/ Polygon.prototype.collideShapes = function(/*Polygon*/ _poly)
                // Ret. TRUE if the shapes intersect
                // slow method
                try     {
                     this.intersectPath(_poly);
                     app.activeDocument.undo();
                     return(true);
                catch(ex)
                     return(false);
                As shown above, the point is that p1.intersectPath(p2) throws an error when the 2 shapes don't intersect.
                Hope it could help you.
                Marc
                • 5. Re: [JS CS3] Touching Objects
                  Harbs. Level 6
                  Yes. Objects of arbitrary shape can be pretty hard to check.
                  If you need a quicker method than intersectPath, you can compare them
                  using the entirePath property of the paths of the two objects, but
                  that's not a job for the faint hearted or someone who dislikes
                  math...
                  Harbs
