2 Replies Latest reply on Nov 12, 2009 4:56 AM by Vidya Kesavan
    Unable to access process variable value in the DXFA file
    Vidya Kesavan
      I am using the On-Demand-Assembly solution accelerator to stitch forms. I am trying to access a process variable inside the dxfa file.
      This is the syntax i used: <c:forEach var="templateItem" items="${requestScope.paramsMap.templateList}"> The templateList value is not being fetched. The same code works fine if I hard code the items.
      paramsMap is set as the Parameters Map variable in the invokeODADocument service.
      Any suggestions on what I might be missing here??
      Thanks.
      Regards,
      Vidya
