I am deploying a LCA archve thru ant scripts.The erroe coming is like
run:
[echo] LC Archives creation and deployment -- In the main ()
[java] Create and deploy LC archive init() called...
[java] Nov 11, 2009 6:09:20 PM com.adobe.idp.applicationmanager.client.Appl
icationManagerClient <init>
[java] INFO: ApplicationManagerClient:init()
[java] ###### -- IN the MAIN -----####
[java]
[java] ###### -- Length of args -----####4
[java] ###### -- IN THE DEPLOY MODE -----####
[java]
[java] Deploying New LCAs...
[java] Nov 11, 2009 6:09:21 PM com.adobe.idp.applicationmanager.client.Appl
icationManagerClient callApplicationManager
[java] INFO: ApplicationManagerClient:callApplicationManager:importApplicat
ionArchive
[java] Nov 11, 2009 6:09:23 PM com.adobe.idp.applicationmanager.client.Appl
[java] SEVERE: ApplicationManagerClient:callApplicationManager:Exception:ja
va.lang.IllegalStateException
[java] java.lang.OutOfMemoryError: Java heap space
[java] at com.adobe.idp.applicationmanager.client.ApplicationManagerCli
ent.callApplicationManager(ApplicationManagerClient.java:108)
[java] at com.adobe.idp.applicationmanager.client.ApplicationManager.im
portApplicationArchive(ApplicationManager.java:147)
[java] ## --- END OF DEPLOYMENT TASK -- ##
[java] at test.com.sample.LCAUtils.CreateAndDeployLCA.OriginaldeployLCA(Cre
ateAndDeployLCA.java:264)
[java]
[java] at test.com.sample.LCAUtils.CreateAndDeployLCA.multipleDeployLCA(Cre
ateAndDeployLCA.java:337)
[java] at test.com.sample.LCAUtils.CreateAndDeployLCA.main(CreateAndDeployL
CA.java:484)
[java] Caused by: java.lang.OutOfMemoryError: Java heap space
here java java code works fine for small sized LCAs but mLCA which is around 8-9 Mb is creating problems
PLease suggest a solution.
REgards,
Prabhat
Views
Total Likes
You get a [java] java.lang.OutOfMemoryError: Java heap space*
Try to increase your JVM max memory size.
Jasmin
Views
Total Likes
