0 Replies Latest reply on Nov 11, 2009 4:48 AM by M.S.H
    Is it possible to convert HTML to XML in as2?
    M.S.H Level 1
      I am trying to develop a stock widget to use in my mobile using flashlite 2.x.
      I have chosen "http://charting.nasdaq.com" to obtain 5days chart /6months chart..
      But I am not able to use XML object for this and parse.. The values are in table format.. So I have to use LoadVars.. but writing a AS2 code
      to obtain values like High/Low price of the stock or volume is very lengthy since the data obtained are not in XML format..
      i tried this
      var example_xml:LoadVars = new LoadVars();
      example.ignoreWhite = true;
      example_xml.load("http://charting.nasdaq.com/ext/charts.dll?2-1-14-0-0-75-03NA000000www-&SF:4|5-WD=539-HT=39 5--XTBL-");
      example_xml.onLoad = function(success) {
           if (success == true) {
                trace(example_xml);
      Is it possible to convert them to xml and use relevent methods or xml properties?
      If I use example_xml:XML = new XML() then tracing example_xml (as above) doesn't give any data
      Any help?
