0 Replies Latest reply on Nov 11, 2009 6:06 AM by jmurphy67
    [svn:fx-trunk] 11651: Merged 3.x revisions 11192,11237,11618 -> trunk
    jmurphy67 Level 1
      Revision: 11651
      Author:   jimurphy@adobe.com
      Date:     2009-11-11 06:06:01 -0800 (Wed, 11 Nov 2009)
      Log Message:
        r11192 | rfrishbe@adobe.com | 2009-10-27 15:54:37 -0400 (Tue, 27 Oct 2009) | 8 lines
        In AIR, you can drag'n drop text between text components like TextInput and TextArea.  There's an AIR bug where doing so doesn't result in a TEXT_INPUT or a CHANGE event.  This is a workaround for that bug so that we listen for a nativeDragDrop event.
        QE notes: -
        Doc notes: -
        Bugs: SDK-19816
        Reviewer: Gordon
        Tests run: checkintests, mustella TextInput, TextArea
        Is noteworthy for integration: no
        r11237 | smgilson@adobe.com | 2009-10-28 15:23:48 -0400 (Wed, 28 Oct 2009) | 9 lines
        Add ASDoc comment to the class. Please integrate into the 3.4.0 branch
        r11618 | aharui@adobe.com | 2009-11-10 13:12:56 -0500 (Tue, 10 Nov 2009) | 11 lines
        Allow extra parameters on itemToLabel so you can use DataGrid as the dropdown in a combobox.
        QE Notes: None
        Doc Notes: While we did change the signature on itemToLabel, I think we shouldn't document the change.  We are allowing extra params so we don't crash and we never use those params so the effective signature is the same
        Bugs: SDK-24027
        Reviewer: Corey
        API Change: No
        Is noteworthy for integration: No
        tests: checkintests mustella/components/ComboBox
      Ticket Links:
          http://bugs.adobe.com/jira/browse/SDK-19816
          http://bugs.adobe.com/jira/browse/SDK-24027
      Modified Paths:
          flex/sdk/trunk/frameworks/projects/framework/src/mx/controls/ComboBox.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/controls/TextArea.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/controls/TextInput.as
          flex/sdk/trunk/frameworks/projects/utilities/src/com/adobe/viewsource/ViewSource.as
      Property Changed:
          flex/sdk/trunk/
