0 Replies Latest reply on Nov 11, 2009 7:16 AM by brianplauger
    Is there a way to change the path of the Skin and FLVPlayer .swfs in Dreamweaver?
    brianplauger
      Hi! I have a simple question that I can't seem to figure out.  I know how to insert an flv via dreamweaver and it is very simple
      see the code --
      <object classid="clsid:D27CDB6E-AE6D-11cf-96B8-444553540000" width="205" height="250" id="FLVPlayer">
          <param name="movie" value="FLVPlayer_Progressive.swf" />
          <param name="quality" value="high" />
          <param name="wmode" value="opaque" />
          <param name="scale" value="noscale" />
          <param name="salign" value="lt" />
          <param name="FlashVars" value="&amp;MM_ComponentVersion=1&amp;skinName=Clear_Skin_1&amp;streamName=flash/flashvid eofile&amp;autoPlay=false&amp;autoRewind=false" />
          <param name="swfversion" value="8,0,0,0" />
          <!-- This param tag prompts users with Flash Player 6.0 r65 and higher to download the latest version of Flash Player. Delete it if you don’t want users to see the prompt. -->
          <param name="expressinstall" value="Scripts/expressInstall.swf" />
          <!-- Next object tag is for non-IE browsers. So hide it from IE using IECC. -->
          <!--[if !IE]>-->
          <object type="application/x-shockwave-flash" data="FLVPlayer_Progressive.swf" width="205" height="250">
            <!--<![endif]-->
            <param name="wmode" value="transparent" />
            <!-- The browser displays the following alternative content for users with Flash Player 6.0 and older. -->
            <div>
              <h4>Content on this page requires a newer version of Adobe Flash Player.</h4>
              <p><a href="http://www.adobe.com/go/getflashplayer"><img src="http://www.adobe.com/images/shared/download_buttons/get_flash_player.gif" alt="Get Adobe Flash player" /></a></p>
            </div>
            <!--[if !IE]>-->
          </object>
          <!--<![endif]-->
        </object>
      The question I have is... How do you change the path settings for the 2 required swfs (the skin swf and the player)?  I would ideally like to have all my flash components including the skin swf and the player swf in the same folder as the flv (rather than have the swfs in the root of the same folder as my html doc), but everytime I try to adjust the path settings of the swfs in the above code I get a white screen.
      hope this makes sense and is not confusing...
      Any suggestions?
      -Brian
