2 Replies Latest reply on Nov 11, 2009 7:47 AM by RayIT
    Need some help.. use component files, refresh data...
    RayIT
      I am struggling for some hours now with a problem,
      I use some component files for a viewstack, now I change the data in 1 component and the data should refresh in the other component.
      Should be easy, could somebody point me in the good direction.
      <mx:ViewStack id="viewStack" right="10" left="10" top="109" bottom="11">
      <!-- GEBRUIKER -->
      <mx:Canvas id="gebruiker" label="gebruiker" width="100%" height="100%" backgroundColor="#f6f6f6" showEffect="WipeDown" hideEffect="WipeUp">
      <comp:user id="user_comp" height="100%" width="100%" />
      </mx:Canvas>
      <!-- CATEGORIE -->
      <mx:Canvas id="categorie" label="categorie" width="100%" height="100%" backgroundColor="#f6f6f6" showEffect="WipeDown" hideEffect="WipeUp">
      <comp:category id="category_comp" width="100%" height="100%" />
      </mx:Canvas>
      If I insert data in the database from the first canvas and I go to the second canvas this data is not refreshes/changed.
      How to trigger this.
      Many thanks
      Raymond
        • 1. Re: Need some help.. use component files, refresh data...
          Arsohoh
          hi,
          Just trying assigning the data from database to some bindable variable and try assigning that variable to the canvas. Am not sure if it works. Pls try..
          • 2. Re: Need some help.. use component files, refresh data...
            RayIT Level 1
            I found a nice sollution which after looking now to it is very simple...
            I just used following to refresh the httpservices in the different components!
            category_comp is the id of the component and the mainCategoryService is the database retrieve service I need to refresh...
            Application.application.category_comp.mainCategoryService.send();
            Application.application.foto_beheer_comp.mainCategoryService.send();
            Now if some one clicks on the menu to go to an other component file I just refresh them.
            many thanks
            Raymond
