2 Replies Latest reply on Nov 11, 2009 10:32 AM by satyajitbehera
    cannot access local resource file
    kapil.rajak
      When I run my application on browser these error comes, I have found to change right click on project>properties>flex build path>libary path> framework linkage to "Merge into code"not working,
      I have also changed right click on project> properties>Flex compiler> Additional compiler arguments - -locale en_US to some -network false still its not working
      and undid whatever change i made,
      Help!
      SecurityError: Error #2148: SWF file http://localhost/aamshare-debug/aamshare.swf cannot access local resource file:///C|/wamp/www/aamshare-debug/media/bse.png. Only local-with-filesystem and trusted local SWF files may access local resources.
          at flash.display::Loader/_load()
          at flash.display::Loader/load()
          at mx.controls::SWFLoader/loadContent()[C:\autobuild\3.2.0\frameworks\projects\framework\src \mx\controls\SWFLoader.as:1611]
          at mx.controls::SWFLoader/load()[C:\autobuild\3.2.0\frameworks\projects\framework\src\mx\con trols\SWFLoader.as:1380]
          at mx.controls::SWFLoader/initializeHandler()[C:\autobuild\3.2.0\frameworks\projects\framewo rk\src\mx\controls\SWFLoader.as:1971]
          at flash.events::EventDispatcher/dispatchEventFunction()
          at flash.events::EventDispatcher/dispatchEvent()
          at mx.core::UIComponent/dispatchEvent()[C:\autobuild\3.2.0\frameworks\projects\framework\src \mx\core\UIComponent.as:9298]
          at mx.core::UIComponent/set processedDescriptors()[C:\autobuild\3.2.0\frameworks\projects\framework\src\mx\core\UICom ponent.as:1217]
          at mx.core::UIComponent/initializationComplete()[C:\autobuild\3.2.0\frameworks\projects\fram ework\src\mx\core\UIComponent.as:5395]
          at mx.core::UIComponent/initialize()[C:\autobuild\3.2.0\frameworks\projects\framework\src\mx \core\UIComponent.as:5379]
          at mx.core::UIComponent/http://www.adobe.com/2006/flex/mx/internal::childAdded()[C:\autobuild\3.2.0\frameworks\pro jects\framework\src\mx\core\UIComponent.as:5267]
          at mx.core::Container/http://www.adobe.com/2006/flex/mx/internal::childAdded()[C:\autobuild\3.2.0\frameworks\pro jects\framework\src\mx\core\Container.as:3305]
          at mx.core::Container/addChildAt()[C:\autobuild\3.2.0\frameworks\projects\framework\src\mx\c ore\Container.as:2217]
          at mx.core::Container/addChild()[C:\autobuild\3.2.0\frameworks\projects\framework\src\mx\cor e\Container.as:2140]
          at mx.core::Container/createComponentFromDescriptor()[C:\autobuild\3.2.0\frameworks\projects \framework\src\mx\core\Container.as:3681]
          at mx.core::Container/createComponentsFromDescriptors()[C:\autobuild\3.2.0\frameworks\projec ts\framework\src\mx\core\Container.as:3493]
          at mx.containers::ViewStack/instantiateSelectedChild()[C:\autobuild\3.2.0\frameworks\project s\framework\src\mx\containers\ViewStack.as:1140]
          at mx.containers::ViewStack/commitProperties()[C:\autobuild\3.2.0\frameworks\projects\framew ork\src\mx\containers\ViewStack.as:664]
          at mx.core::UIComponent/validateProperties()[C:\autobuild\3.2.0\frameworks\projects\framewor k\src\mx\core\UIComponent.as:5807]
          at mx.managers::LayoutManager/validateProperties()[C:\autobuild\3.2.0\frameworks\projects\fr amework\src\mx\managers\LayoutManager.as:539]
          at mx.managers::LayoutManager/doPhasedInstantiation()[C:\autobuild\3.2.0\frameworks\projects \framework\src\mx\managers\LayoutManager.as:659]
          at Function/http://adobe.com/AS3/2006/builtin::apply()
          at mx.core::UIComponent/callLaterDispatcher2()[C:\autobuild\3.2.0\frameworks\projects\framew ork\src\mx\core\UIComponent.as:8628]
          at mx.core::UIComponent/callLaterDispatcher()[C:\autobuild\3.2.0\frameworks\projects\framewo rk\src\mx\core\UIComponent.as:8568]
