2 Replies Latest reply on Nov 13, 2009 8:24 AM by Steve_Porter
    Is there a way to apply a cornerRadius to a LinkButton background (opaqueBackground)?
    Steve_Porter Level 1
      Is there a way to have the static background mimic the cornerRadius that may get applied to the rollover state?
      See the attached pictures to see the disconnect - or run this example code and rollover the LinkButton (I'd like the background to be rounded and match the rollover state).
      <!-- http://blog.flexexamples.com/2008/09/02/setting-the-corner-radius-of-a-linkbutton-control- in-flex/ -->
      <mx:Application name="LinkButton_cornerRadius_test"
              xmlns:mx="http://www.adobe.com/2006/mxml"
              layout="vertical"
              verticalAlign="middle"
              backgroundColor="white">
          <mx:LinkButton id="linkButton"
                  label="LinkButton"
                  cornerRadius="10"
                  opaqueBackground="0xAAAAAA" />
          <mx:Label text="Roll over the link button to see corner radius - but notice the background still has hard edges" />
          <mx:Label text="I would like to have the opaqueBackground to be rounded as well." />
      </mx:Application>
        • 1. Re: Is there a way to apply a cornerRadius to a LinkButton background (opaqueBackground)?
          Ramakrishnan SRK
          Why don't you apply skin on LinkButton? Here is the sample
          LinkButton {
          upSkin:Embed("assets/images/linkbutton-up.png");
          overSkin:Embed("assets/images/linkbutton-over.png");
          downSkin:Embed("assets/images/linkbutton-down.png");
          <mx:LinkButton id="linkButton" label="LinkButton" />
          The images are attached.
          • 2. Re: Is there a way to apply a cornerRadius to a LinkButton background (opaqueBackground)?
            This doesn't quite answer the problem.
            I may have not been clear about what I was trying to achieve - I'm changing the background color (opaqueBackground) to show current selection of the selected mode in the LinkButton.  ...but I would like this "selection/background" to be rounded to be consistent with the look and feel (all other elements are rounded).
            <mx:Application
                     xmlns:mx="
                      layout="
            vertical"
                      verticalAlign="
            middle"
                      backgroundColor="
            white">
                <mx:Style source="assets/styles/styles.css">
                </mx:Style>
                <mx:Script>
                <![CDATA[
                      import mx.controls.Alert;
                      private function selectionClick(event:Event):void
                          if(event.target.id == "selectionA")
                                selectionA.selected =
            true;
                                selectionB.selected =
            false;
                                selectionC.selected =
            false;
                                selectionA.opaqueBackground = 0xDAD9AD;
                                selectionB.opaqueBackground = 0xFFFFFF;
                                selectionC.opaqueBackground = 0xFFFFFF;
                           else if(event.target.id == "selectionB")
            false;
            true;
            false;
                                selectionA.opaqueBackground = 0xFFFFFF;
                                selectionB.opaqueBackground = 0xDAD9AD;
                           else if(event.target.id == "selectionC")
            false;
            false;
            true;
                                selectionC.opaqueBackground = 0xDAD9AD;
                           else
            Got an event from an invalid source: " + event.target.id, "Error");
                 </mx:Script>
                 <mx:LinkButton label="Selection A"
                      id="
            selectionA"
                      click="selectionClick(event)"
                      selected="t
            rue"
            DAD9AD" />
                 <mx:LinkButton label="Selection B"
                      id="
            selectionB"
                 <mx:LinkButton label="Selection C"
                      id="
            selectionC"
            </mx:Application>
            </mx:Application>
            </mx:Application>
