1 Reply Latest reply on Nov 17, 2009 6:23 AM by WebDevByGeorge
    Installing Beta 2 into existing Eclipse
    Trevor H
      I went through the steps to get eclipse working with the beta 2 plugin found here: http://forums.adobe.com/message/2343041#2343041 but I'm unable to get the perspective to show up.
      Chris mentioned in this reply http://forums.adobe.com/message/2332788#2332788 that an error in another installation would prevent FB from being added.  I found an error in another installation (Resource Monitoring Common Feature).  After googling around I'm still not sure how to fix it. Do I need to reinstall eclipse from scratch?  Configuration screenshot attached.
      Trevor
        • 1. Re: Installing Beta 2 into existing Eclipse
          WebDevByGeorge Level 1
          I am having the same difficulty.  When I run the Beta 2 plugin with existing eclipse I can see the Flash Perspective.  When I run my existing copy I do not see it.  I do, however, see the Flash Profile perspective available.  I looked at my configuration and everything seems to be configured correctly and not showing disabled like your plugin so I'm not sure if we're having the same issue or not.
