12 Replies Latest reply on Nov 12, 2009 11:58 AM by GeorgeWS
    AdvancedDataGridRendererProvider
    GeorgeWS Level 1
      I have been at this all day everyday for almost a month. I have an ADG filled with an arrayCollection from a RO. I have read all about the
      AdvancedDataGridRendererProvider I can get the column spanning and the right row but not the right data. I read that this works:
      note: the data I want is REMA2W (this is a long description) this is called summaryRenderer.mxml
      <mx:Canvas
      xmlns:mx="http://www.adobe.com/2006/mxml">
      <mx:Label id="rowLabel" textAlign="left" width="100%">
      <mx:Script>
      <![CDATA[
      override public function set data(value:Object):void
      super
      .data = value;
      rowLabel.htmlText = data.REMA2W;
      </mx:Script>
      </mx:Label>
      But sadly it does not. If I do this: rowLabel.htmlText = data.GroupField; I get the data but its not what I want.
      This is my renderer:
      <mx:rendererProviders>
      <mx:AdvancedDataGridRendererProvider dataField="REMA2W" columnSpan="5" columnIndex="0" depth="1"
      renderer="
      SummaryRenderer"/>
      </mx:rendererProviders>
      How do I see what the data that is available to me is?
      This is my ADG:
      id="adg" defaultLeafIcon="{null}" displayItemsExpanded="true" width="100%" height="100%" themeColor="#73B9B9" initialize="gc.refresh()">
      <mx:dataProvider>
      <mx:GroupingCollection id="gc" source="{myWine}">
      <mx:Grouping groupingObjectFunction="grpObjFunc">
      <mx:GroupingField id="gf" name="myHeader">
      <mx:Array id="summ">
      <mx:SummaryRow summaryPlacement="group">
      <mx:fields>
      <mx:SummaryField dataField="REMA2W" label="REMA2W"/>
      <mx:SummaryField dataField="myList" operation="SUM" label="myTotal"/>
      </mx:fields>
      </mx:SummaryRow>
      </mx:Array>
      </mx:GroupingField>
      </mx:Grouping>
      </mx:GroupingCollection>
      </mx:dataProvider>
      <mx:groupedColumns>
      <mx:AdvancedDataGridColumn dataField="CMPT2W" headerText="Item" width="110"/>
      <mx:AdvancedDataGridColumn dataField="DESCRIP" headerText="Desc"/>
      <mx:AdvancedDataGridColumn dataField="SDIVDE" headerText="Size" width="50"/>
      <mx:AdvancedDataGridColumn dataField="NOFF2W" headerText="Btls" width="50" textAlign="right"/>
      <mx:AdvancedDataGridColumn dataField="BPRC5W" headerText="Inc BBC" width="60" textAlign="right" />
      <mx:AdvancedDataGridColumn dataField="myList" headerText="List" width="60" textAlign="right" />
      <mx:AdvancedDataGridColumn dataField="myTotal" itemRenderer="NumberItemRenderer" headerText="Cost" width="60" textAlign="right"/>
      <mx:AdvancedDataGridColumnGroup headerText="Inventory">
      <mx:AdvancedDataGridColumn dataField="INV_41" headerText="Morgan Hill" width="60" textAlign="right" visible="{myDetail.selected}"/>
      <mx:AdvancedDataGridColumn dataField="INV_31" headerText="Chino" width="60" textAlign="right" visible="{myDetail.selected}"/>
      </mx:AdvancedDataGridColumnGroup>
      </mx:groupedColumns>
      <mx:AdvancedDataGridRendererProvider dataField="REMA2W" columnSpan="6" columnIndex="0" depth="1"
      renderer="
      com.esria.samples.dashboard.view.SummaryRenderer"/>
      </mx:AdvancedDataGrid>
      I have read that the data. property has all the elements from the row. I just dont know how to see them.
      EVERYTHING in my app works perfect except landing the REMA2W in the group and in the 2nd column.
      George
        • 1. Re: AdvancedDataGridRendererProvider
          paul.williams Level 4
          Summary rows are generated by the GroupingCollection so they do not contain the same sets of fields as your data rows. In your example your summary rows will contain the following fields:
          GroupLabel - the label for your group as defined by your GroupingField
          REMA2W - a summation of all the REMA2W fields in the corresponding group
          myTotal - a summation of all the myList fields in the correspinding group
          children - an array of the group's child rows
          I'm basing this on the "Creating Summary Rows" section of the link below (search for "Internally, the GroupingCollection"):
          http://livedocs.adobe.com/flex/3/html/help.html?content=advdatagrid_02.html
          Previously I asked you to put in the following debug code:
          for ( var property : String in data )
               trace( property + ": " + data[ property ] );
          You replied that you saw the following: grouping label, the cost field, an NaN and an Object. That's 4 fields as expected. Unfortunately you did not follow the instructions exactly so we got no property names. I would suggest trying again to get property names and values using this approach.
          • 2. Re: AdvancedDataGridRendererProvider
            GeorgeWS Level 1
            I see the 4 parts:
            REMA2W : NaN
            children: [object Object]
            myTotal: 174
            GroupLabel: 900051111      HARDY VS 6B
            uid: 900051111      HARDY VS 6B
            This is what I want REMA2W to be: Purchase 5 bottles Hardy VS Ltr & receive 1 bottle Hardy VS AAD, No BCC. ($19.58 Net BC)
            So now that I see what going to the SummaryRenderer. I see that there is nothing for the REMA2W so this is not possible?
            I read online and in Flex 3 Training from the Source that this should work:
            data.REMA2W
            George
            • 3. Re: AdvancedDataGridRendererProvider
              Ok, I'm coding this blind so it may not work the first time, but try the following in your renderer:
                 super.data = value;
                 var groupChildren : Array = data.children as Array;
                 if ( groupChildren.length > 0 )
                    var firstRowInGroup : Object = groupChildren[ 0 ];
                    rowLabel.htmlText = firstRowInGroup.REMA2W;
                 else
                    rowLabel.htmlText = "n/a";
              It attempts to get the REMA2W field of the first row in the group.
              • 4. Re: AdvancedDataGridRendererProvider
                GeorgeWS Level 1
                I wish I could be pressing the Answered button, but the result freezes the screen. I have been stuck on Fex stuff for days but weeks, almost a month is rediculous. Any other thoughts. Is there a function in Flex that will chop off the first 50 chars? That would do it
                Thanks again
                George
                • 5. Re: AdvancedDataGridRendererProvider
                  Do you have the debug player installed?
                  There is probably an error being thrown, try the following:
                    super.data = value;
                    try
                       else
                     catch ( e : Error )
                        rowLabel.htmlText = e.message;
                  • 6. Re: AdvancedDataGridRendererProvider
                    GeorgeWS Level 1
                    I have tried many times to install the debugger edition but never works. Thats as painful as this issue.
                    But what you sent to me does produce an error (surprisingling exactally where I want my REMA2W.
                    The error is: error #1009
                    Not sure what that means
                    • 7. Re: AdvancedDataGridRendererProvider
                      Unfortunately without debugging tools this is going to require some trial and error, but we are making progress. Try the following and tell me what appears in your field:
                      import flash.utils.getQualifiedClassName;
                        super.data = value;
                        try
                           rowLabel.htmlText = getQualifiedClassName( data.children );
                        catch ( e : Error )
                      • 8. Re: AdvancedDataGridRendererProvider
                        GeorgeWS Level 1
                        I get this:
                        faultCode:Client.Error.MessageSend faultString:'Send failed' faultDetail:'Channel.Connect.Failed error NetConnection.Call.Failed: HTTP: Status 500: url: 'http://intranet.youngsmarket.com/flex2gateway/''
                        and nothing loads
                        • 9. Re: AdvancedDataGridRendererProvider
                          I think that's a separate issue. A 500 error indicates an internal server fault.
                          • 10. Re: AdvancedDataGridRendererProvider
                            GeorgeWS Level 1
                            OK got that issue solved (JRun hangs almost once a day, sucks) anyways I get this:
                            mx:collections::ArrayCollection
                            • 11. Re: AdvancedDataGridRendererProvider
                              Ok that explains our earlier error. Try this:
                                super.data = value;
                                try
                                   var groupChildren : ArrayCollection = data.children as ArrayCollection;
                                   else
                                 catch ( e : Error )
                              • 12. Re: AdvancedDataGridRendererProvider
                                GeorgeWS Level 1
                                Paul,
                                Your are a true master, thanks for hanging in there with me.
                                George
