0 Replies Latest reply on Nov 11, 2009 11:58 AM by Carol L. Frampton
    [svn:fx-trunk] 11665: TLF Build 549.
    Carol L. Frampton Level 2
      Revision: 11665
      Author:   cframpto@adobe.com
      Date:     2009-11-11 11:58:47 -0800 (Wed, 11 Nov 2009)
      Log Message:
      TLF Build 549.  Includes the html converter support we have been waiting for.
      QE notes:
      Doc notes:
      Bugs:
      Reviewer:
      Tests run: checkintests, TextArea, TextInput, NumericStepper
      Is noteworthy for integration: no
      Modified Paths:
          flex/sdk/trunk/frameworks/air-config.xml
          flex/sdk/trunk/frameworks/flex-config.xml
          flex/sdk/trunk/frameworks/libs/textLayout.swc
          flex/sdk/trunk/frameworks/projects/textLayout/HowToUpgradeTLF.txt
          flex/sdk/trunk/frameworks/projects/textLayout/ReleaseNotes.txt
          flex/sdk/trunk/frameworks/projects/textLayout/build.xml
          flex/sdk/trunk/frameworks/projects/textLayout/src/flashx/textLayout/BuildInfo.as
          flex/sdk/trunk/frameworks/projects/textLayout/src/flashx/textLayout/CoreClasses.as
          flex/sdk/trunk/frameworks/projects/textLayout/src/flashx/textLayout/EditClasses.as
          flex/sdk/trunk/frameworks/projects/textLayout/src/flashx/textLayout/compose/BaseCompose.a s
          flex/sdk/trunk/frameworks/projects/textLayout/src/flashx/textLayout/container/TextContain erManager.as
          flex/sdk/trunk/frameworks/projects/textLayout/src/flashx/textLayout/conversion/BaseTextLa youtImporter.as
          flex/sdk/trunk/frameworks/projects/textLayout/src/flashx/textLayout/conversion/HtmlExport er.as
          flex/sdk/trunk/frameworks/projects/textLayout/src/flashx/textLayout/conversion/HtmlImport er.as
          flex/sdk/trunk/frameworks/projects/textLayout/src/flashx/textLayout/conversion/TextLayout Importer.as
          flex/sdk/trunk/frameworks/projects/textLayout/src/flashx/textLayout/edit/EditManager.as
          flex/sdk/trunk/frameworks/projects/textLayout/src/flashx/textLayout/edit/IEditManager.as
          flex/sdk/trunk/frameworks/projects/textLayout/src/flashx/textLayout/edit/ParaEdit.as
          flex/sdk/trunk/frameworks/projects/textLayout/src/flashx/textLayout/edit/SelectionManager .as
          flex/sdk/trunk/frameworks/projects/textLayout/src/flashx/textLayout/edit/TextFlowEdit.as
          flex/sdk/trunk/frameworks/projects/textLayout/src/flashx/textLayout/elements/Configuratio n.as
          flex/sdk/trunk/frameworks/projects/textLayout/src/flashx/textLayout/elements/FlowElement. as
          flex/sdk/trunk/frameworks/projects/textLayout/src/flashx/textLayout/elements/FlowGroupEle ment.as
          flex/sdk/trunk/frameworks/projects/textLayout/src/flashx/textLayout/elements/FlowLeafElem ent.as
          flex/sdk/trunk/frameworks/projects/textLayout/src/flashx/textLayout/elements/IConfigurati on.as
          flex/sdk/trunk/frameworks/projects/textLayout/src/flashx/textLayout/elements/InlineGraphi cElement.as
          flex/sdk/trunk/frameworks/projects/textLayout/src/flashx/textLayout/elements/LinkElement. as
          flex/sdk/trunk/frameworks/projects/textLayout/src/flashx/textLayout/elements/ParagraphEle ment.as
          flex/sdk/trunk/frameworks/projects/textLayout/src/flashx/textLayout/elements/SpanElement. as
          flex/sdk/trunk/frameworks/projects/textLayout/src/flashx/textLayout/elements/TextFlow.as
          flex/sdk/trunk/frameworks/projects/textLayout/src/flashx/textLayout/formats/ITextLayoutFo rmat.as
          flex/sdk/trunk/frameworks/projects/textLayout/src/flashx/textLayout/formats/LeadingModel. as
          flex/sdk/trunk/frameworks/projects/textLayout/src/flashx/textLayout/formats/TextLayoutFor mat.as
          flex/sdk/trunk/frameworks/projects/textLayout/src/flashx/textLayout/formats/TextLayoutFor matInc.as
          flex/sdk/trunk/frameworks/projects/textLayout/src/flashx/textLayout/formats/TextLayoutFor matValueHolder.as
          flex/sdk/trunk/frameworks/projects/textLayout/src/flashx/textLayout/operations/ApplyForma tOperation.as
          flex/sdk/trunk/frameworks/projects/textLayout/src/flashx/textLayout/operations/InsertText Operation.as
          flex/sdk/trunk/frameworks/projects/textLayout/src/flashx/textLayout/property/Property.as
          flex/sdk/trunk/frameworks/projects/textLayout/src/flashx/textLayout/property/TabStopsProp erty.as
          flex/sdk/trunk/frameworks/projects/textLayout/tlf.properties
      Added Paths:
          flex/sdk/trunk/frameworks/projects/textLayout/src/flashx/textLayout/elements/GlobalSettin gs.as
          flex/sdk/trunk/frameworks/projects/textLayout/src/flashx/textLayout/operations/UndefineFo rmatOnElementOperation.as
          flex/sdk/trunk/frameworks/projects/textLayout/src/flashx/textLayout/operations/UndefineFo rmatOperation.as
          flex/sdk/trunk/frameworks/rsls/textLayout_1.0.0.549.swf
      Removed Paths:
          flex/sdk/trunk/frameworks/projects/textLayout/src/flashx/textLayout/acc/TextAccImpl.as
          flex/sdk/trunk/frameworks/projects/textLayout/src/flashx/textLayout/elements/GlobalConfig uration.as
          flex/sdk/trunk/frameworks/rsls/textLayout_1.0.0.547.swf
