How to make an updateable recordset in CS4 (asp)?
LoriKB Nov 11, 2009 1:23 PMHello,
I've been searching for a couple hours now and have been unable to find an answer to this question. I was using MX 2004 until recently (yes I know very old) but I was pretty set in my ways
This is currently my enemy "Current Recordset does not support updating. This may be a limitation of the provider, or of the selected locktype."
I could correct this in previous versions by changing the locktype or cursorlocation/type but these don't seem to be available to change in a Command Object?
Am I doomed to writing out all my recordsets from now on? I am sure the command object makes a more secure recordset but that doesn't help me if I can't write a simple update statement.
If there is a way for me to make this updateable that would be great, if not please reply with that so I can atleast stop looking and just write the recordset (probably something I should have done after looking for 5 minutes with no answers lol)
here is my code
Set rsThisMember_cmd = Server.CreateObject ("ADODB.Command")
rsThisMember_cmd.ActiveConnection = MM_Conn_UBF_STRING
rsThisMember_cmd.CommandText = "SELECT * FROM dbo.tblCMS834_Temp WHERE Id = ?"
rsThisMember_cmd.Prepared = true
rsThisMember_cmd.Parameters.Append rsThisMember_cmd.CreateParameter("param1", 5, 1, -1, rsThisMember__MMColParam) ' adDouble
Set rsThisMember = rsThisMember_cmd.Execute
My update is conditional based on whether the user hits approve or reject and only changes two fields which is why I want to write my own update code rather than use the dreamweaver update server behavior.
<% IF Request.ServerVariables("REQUEST_METHOD") = "POST" Then
If Request.Form("Submit") = "Reject" Then
rsThisMember.MoveFirst
rsThisMember("Approved") = "No"
rsThisMember("TimeStamp") = Date()
rsThisMember.Update
End If
If Request.Form("Submit") = "Approve" Then
rsThisMember("Approved") = "Yes"
rsThisMember.Update
End If
End If
I probably put in too much information but I figured it was better if people knew what I was trying to do. Should be simple. I am fne with writing my own recordset but this is something I do A LOT so it would be great if I knew if there was a way to change the Command Object rather than use Recordset.Open.
Thanks so much,
Lori
