5 Replies Latest reply on Nov 11, 2009 9:19 PM by EZ_paco99
    Unable to connect to the server to pull data from mysql
      I am novice working with Flash Builder 4 and I just created a test application which runs well in my computer pulling data from Mysql using PHP and populating a datagrid. But when I transfered it to the my hosting provider failed. I have been doing some modifications to the gateway.php and amf.config.ini to solve some of the issues. Now the application try to run but doesn't populate the data in the datagrid. I included a tracking point in my data service file to read the connections variables, but they come up in blank. I highly appreciate any help. Here are my gateway.php, amf.config.ini and the data service.
      ini_set("display_errors", 1);
      $dir = dirname(__FILE__);
      $webroot = $_SERVER['DOCUMENT_ROOT'];
      $configfile = "$dir/amf_config.ini";
      $fp = fopen("tracking.txt", "a");
      fwrite($fp, "1-config file " . $configfile . "\r\n");
      //default zend install directory
      $zenddir = $webroot. '/ZendFramework/library';
      //-$zenddir = $webroot;
      fwrite($fp, "2-default zendir" . $zenddir . "\r\n");
      //Load ini file and locate zend directory
      if(file_exists($configfile)) {
                $webroot = $arr['zend']['webroot'];
                $zenddir = $arr['zend']['zend_path'];
      fwrite($fp, "3-after zendir" . $zenddir . "\r\n");
      // Setup include path
      //add zend directory to include path
      // Initialize Zend Framework loader
      require_once 'Zend/Loader/Autoloader.php';
      //-require_once 'Autoloader.php';
      // Load configuration
      $default_config = new Zend_Config(array("production" => false), true);
      $default_config->merge(new Zend_Config_Ini($configfile, 'zendamf'));
      $amf = $default_config->amf;
      fwrite($fp, "4- configfile" . $dafault_config["production"] . "\r\n");
      // Store configuration in the registry
      Zend_Registry::set("amf-config", $amf);
      // Initialize AMF Server
      $server = new Zend_Amf_Server();
      if(isset($amf->directories)) {
           $dirs = $amf->directories->toArray();
           foreach($dirs as $dir) {
               // get the first character of the path.
               // If it does not start with slash then it implies that the path is relative to webroot. Else it will be treated as absolute path
               $length = strlen($dir);
               $firstChar = $dir;
               if($length >= 1)
                    $firstChar = $dir[0];
               if($firstChar != "/"){
                    // if the directory is ./ path then we add the webroot only.
                    if($dir == "./"){
                         $tempPath = $webroot . "/" . $dir;
      fwrite($fp, "5-temp path" . $tempPath . "=>" . "\r\n");
      fwrite($fp, "******************************************" . "\r\n");
      // Initialize introspector for non-production
      if(!$amf->production) {
           $server->setClass('Zend_Amf_Adobe_Introspector', '', array("config" => $default_config, "server" => $server));
              $server->setClass('Zend_Amf_Adobe_DbInspector', '', array("config" => $default_config, "server" => $server));
      // Handle request
      echo $server->handle();
      ;set the absolute location path of webroot directory, example:
      ;Windows: C:\apache\www
      ;MAC/UNIX: /user/apache/www
      ;-webroot =c:/wamp/www/
      webroot = /home/frutiexp/public_html
      ;set the absolute location path of zend installation directory, example:
      ;Windows: C:\apache\PHPFrameworks\ZendFramework
      ;MAC/UNIX: /user/apache/PHPFrameworks/ZendFramework
      ;zend_path = /home/frutiexp/public_html/ZendFramework
      amf.production = true
      *  README for sample service
      *  This generated sample service contains functions that illustrate typical service operations.
      *  Use these functions as a starting point for creating your own service implementation. Modify the
      *  function signatures, references to the database, and implementation according to your needs.
      *  Delete the functions that you do not use.
      *  Save your changes and return to Flash Builder. In Flash Builder Data/Services View, refresh
      *  the service. Then drag service operations onto user interface components in Design View. For
      *  example, drag the getAllItems() operation onto a DataGrid.
      *  This code is for prototyping only.
      *  Authenticate the user prior to allowing them to call these methods. You can find more
      *  information at <link>
      class CoursesService {
           var $username = "myusername";
           var $password = "mypassword"
           var $server = "localhost";
           var $port = "3306";
           var $databasename = "frutiexp_trainsur";
           var $tablename = "courses";
           var $connection;
            * The constructor initializes the connection to database. Everytime a request is
            * received by Zend AMF, an instance of the service class is created and then the
            * requested method is invoked.
           public function __construct() {
                  $this->connection = mysqli_connect(
      $fp = fopen("./tracking.txt", "a");
      fwrite($fp, "1-service".  $databasename . " " . $username . "\r\n");
            * Returns all the rows from the table.
            * Add authroization or any logical checks for secure access to your data
            * @return array
           public function getAllCourses() {
                $stmt = mysqli_prepare($this->connection, "SELECT * FROM $this->tablename");
                $rows = array();
                mysqli_stmt_bind_result($stmt, $row->cou_id, $row->cou_title, $row->cou_overview, $row->cou_objectives);
               while (mysqli_stmt_fetch($stmt)) {
                 $rows[] = $row;
                 $row = new stdClass();
               return $rows;
            * Returns the item corresponding to the value specified for the primary key.
            * @return stdClass
