6 Replies Latest reply on Nov 12, 2009 9:19 AM by dhishok
    replace styles script needed
    rpollack-2 Level 1
      Does anyone know of a script that will allow me to replace one paragraph style with another. I would like a something that would list all the paragraph styles in one list box and have another list box for "replace with..."
      Paragraph Styles
      Change to Style
      BODY 10/12BODY 12/15
      BODY 12/15
      MY STYLE 10/12 ITALIC W/GREPMY STYLE 10/12 BOLD W/GREP
      Something like this
      Thanks in advance
      RPP
        • 1. Re: replace styles script needed
          AdobeScripts Level 3
          hi
          for PC or for Mac ?
          robin
          www.adobescripts.co.uk
          • 2. Re: replace styles script needed
            rpollack-2 Level 1
            maybe I don't load these scripts correctly, however none of the "exe" scripts that I place in the scripts panel folder in my InDesign CS4 ever work.
            Is there some way to get these scripts as javascript and not exe files?
            Also, I went to the link and looked at all the scripts there. I did not see one that does what I need. The "replace style" script suggested will not work, as (if I have read the description correctly) it will replace a "used" style with an "unused" style. What if I want to replace one used style with another style already used?
            Thanks for you suggestions.
            RPP
            • 3. Re: replace styles script needed
              Kasyan Servetsky Level 5
              This is very basic — it doesn't check if any document is open, or the styles exist, etc.
              app.findTextPreferences = app.changeTextPreferences = null;
              app.findTextPreferences.appliedParagraphStyle = "BODY 10/12";
              app.changeTextPreferences.appliedParagraphStyle = "BODY 12/15";
              myDoc.changeText();
              app.findTextPreferences.appliedParagraphStyle = "MY STYLE 10/12 ITALIC W/GREP";
              app.changeTextPreferences.appliedParagraphStyle = "MY STYLE 10/12 BOLD W/GREP";
              myDoc.changeText();
              // and so on, or if you have a lot of styles to change, create 2 arrays:
              // with find-change names and loop thru them in a for loop
              Hope it helps.
              Kasyan
              • 4. Re: replace styles script needed
                hi
                all my scripts are created for PC platform only - they are compiled VisualBasic scripts - not VBScripts
                if you are reffering to "Replace Styles" script - it was created for old ID's - before Adobe added option to replace styles during import DOC/RTF (there is error on screen - on right there is list of all char/para styles - not only "unused")
                the closest script for your needs would be SerialReplace (http://www.adobescripts.com/search.php?query=serialreplace&action=results)
                robin
                • 5. Re: replace styles script needed
                  dhishok Level 1
                  Here is the method Find/Change to replace one style to another...
                  myFStyles=["BODY 10/12", "MY STYLE 10/12 ITALIC W/GREP"]; //add some more styles in find array;
                  myRStyles=["BODY 12/15", "MY STYLE 10/12 BOLD W/GREP"]; //add some more styles in change array;
                  var j=0;
                  for (i=0; i<myFStyles.length; i++){
                          app.findTextPreferences=app.changeTextPreferences=null;
                          app.findTextPreferences.appliedParagraphStyle=myFStyles[i];
                          app.changeTextPreferences.appliedParagraphStyle=myRStyles[j];
                          app.documents.item(0).changeText();
                          j++;
                  alert ("DONE!");
                  I hope this will help you.
                  Thanks & Regards
                  Thiyagu
                  • 6. Re: replace styles script needed
                    rpollack-2 Level 1
                    thanks, I will look this over in the next couple of days.
                    RPP
