2 Replies Latest reply on Nov 12, 2009 1:33 AM by Dallas Kuhn
    Quick Start Help
    apis2009
      Hello i am currently evaluating livecycle. I am following the quick start tutorial - creating a purchase order form. But after finish and want to preview the pdf, this pop up error apear :
      Please give me advise.
      Thank You
        • 1. Re: Quick Start Help
          Dallas Kuhn Level 3
          Your script language is not correct. If you use formCalc, you have to select formcalc from the language drop down list at the top right the script editor. if you use javascript, then you have so select javascript from the drop down. This has to be done for each field with code in it. That will sort out your problem.
          • 2. Re: Quick Start Help
            Dallas Kuhn Level 3
            Alternatively, you need a field called unitPrice in the heirarchy cos the script is looking for it. if this field has a different name, the script wont work.
