0 Replies Latest reply on Nov 12, 2009 5:15 AM by René Mølsted
    [IDS][AS] Will not close document
    René Mølsted Level 1
      I have a hotfolder (Folder Action) that opens dropped files, exports as PDF and then should close but it does not. If I remove the export function it works just fine.
      tell application "InDesignServer"
           activate
           set myDoc to open the_dropped_file_path as string
           export document 1 format PDF type to myFile & "_lowres.pdf" as string using "[Smallest File Size]"
           if (count documents) is not equal to 0 then
                close document 1 saving no
           else
                display dialog "No documents are open."
           end if
      end tell
      René
