4 Replies Latest reply on Nov 12, 2009 4:53 PM by Chuck A. McIntyre
    Still weird problems with CS4/My new computer
    Same-eYes
      Here is situation. Machine works very well when I´m editing HD video but soon as I start edit multi-cam: PROBLEMS! And as I watch from monitor that materia that I been edited so far, it works well, but as soon as I try to change cameras, everything slows-down. Like there is too little memory or something. Could the problem be somewhere in that CS4 program? Because I watch same time those CPU/Memory values and they don´t go very hight. CPU about max. 40% and Memory max 4Gb. And basicly: Is thia computer powerfull enough for Creative Suite CS4
      My graphics card is, ATI Radeon HD 4870. I have update my bios and  Radeon should be 64bit with latest drivers.
      I have ran PassMark Performance test again and again. 2D results are mysterious low and also  disk results ( sequenta write/random seek).
      Everydays I got bluescreens (Bad_Pool-Header, Bad-Pool_Caller etc.)
      Also I´ve notised that in that computer shop they connect those Hard-drives in in SAT 3 and 4. Should they be connected in 1 & 2?
      Also my "first" hard-drive (C:) shoud be very fast, 10 000rpm but in that performance test, and also in Windows hard-drive test results shows, that information does not move as fast as it should be?
      Hard-drive is 300 GB ATA II VelociRaptor drive model FS WD3000HLFS
      ( http://wdc.custhelp.com/cgi-bin/wdc.cfg/php/enduser/std_adp.php?p_faqid=2503 ). Is that hard-drive appropriate for Windows 7 or vise versa?
      Or could that problem be in my memory chips?
      In here I ad my DxDiag-file. I wonder why there said that in displey devices: Current Mode: 1920 x 1200 (32 bit) (59Hz) ?? Should it be 645Bit be cause displaycard is 64bit ???
      System Information
      Time of this report: 11/11/2009, 21:51:10
             Machine name: OMISTAJA-PC
         Operating System: Windows 7 Professional 64-bit (6.1, Build 7600) (7600.win7_rtm.090713-1255)
                 Language: Finnish (Regional Setting: Finnish)
      System Manufacturer: System manufacturer
             System Model: System Product Name
                     BIOS: BIOS Date: 09/03/09 15:52:51 Ver: 08.00.15
                Processor: Intel(R) Core(TM) i7 CPU         920  @ 2.67GHz (8 CPUs), ~2.7GHz
                   Memory: 12288MB RAM
      Available OS Memory: 12280MB RAM
                Page File: 2387MB used, 22168MB available
              Windows Dir: C:\Windows
          DirectX Version: DirectX 11
      DX Setup Parameters: Not found
         User DPI Setting: Using System DPI
      System DPI Setting: 96 DPI (100 percent)
          DWM DPI Scaling: Disabled
           DxDiag Version: 6.01.7600.16385 64bit Unicode
      DxDiag Notes
            Display Tab 1: No problems found.
              Sound Tab 1: No problems found.
              Sound Tab 2: No problems found.
              Sound Tab 3: No problems found.
                Input Tab: No problems found.
      DirectX Debug Levels
      Direct3D:    0/4 (retail)
      DirectDraw:  0/4 (retail)
      DirectInput: 0/5 (retail)
      DirectMusic: 0/5 (retail)
      DirectPlay:  0/9 (retail)
      DirectSound: 0/5 (retail)
      DirectShow:  0/6 (retail)
      Display Devices
                Card name: ATI Radeon HD 4800 Series
             Manufacturer: ATI Technologies Inc.
                Chip type: ATI display adapter (0x9440)
                 DAC type: Internal DAC(400MHz)
               Device Key: Enum\PCI\VEN_1002&DEV_9440&SUBSYS_22671787&REV_00
           Display Memory: 4083 MB
         Dedicated Memory: 1015 MB
            Shared Memory: 3067 MB
             Monitor Name: Yleinen PnP-näyttölaite
            Monitor Model: Q241WB-2
               Monitor Id: VSCDC21
              Native Mode: 1920 x 1200(p) (59.950Hz)
              Output Type: HD15
              Driver Name: atiumd64.dll,atidxx64.dll,atiumdag,atidxx32,atiumdva,atiumd6a.cap,atitmm64.dll
      Driver File Version: 8.14.0010.0700 (English)
           Driver Version: 8.661.0.0
              DDI Version: 10.1
             Driver Model: WDDM 1.1
        Driver Attributes: Final Retail
         Driver Date/Size: 9/24/2009 00:00:58, 4649472 bytes
              WHQL Logo'd: Yes
          WHQL Date Stamp:
        Device Identifier: {D7B71EE2-D700-11CF-8B76-6D02A1C2C535}
                Vendor ID: 0x1002
                Device ID: 0x9440
                SubSys ID: 0x22671787
              Revision ID: 0x0000
      Driver Strong Name: oem15.inf:ATI.Mfg.NTamd64.6.1:ati2mtag_R7X:8.661.0.0:pci\ven_1002&dev_9440
           Rank Of Driver: 00E62001
              Video Accel: ModeMPEG2_A ModeMPEG2_C
         Deinterlace Caps: {6E8329FF-B642-418B-BCF0-BCB6591E255F}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
                           {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
                           {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
                           {6E8329FF-B642-418B-BCF0-BCB6591E255F}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
                           {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
                           {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
                           {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(YV12,0x32315659) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                           {3C5323C1-6FB7-44F5-9081-056BF2EE449D}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,2) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
                           {552C0DAD-CCBC-420B-83C8-74943CF9F1A6}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,2) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
                           {6E8329FF-B642-418B-BCF0-BCB6591E255F}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
                           {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
                           {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
                           {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC1,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                           {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC2,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                           {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC3,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                           {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC4,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                           {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(S340,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                           {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(S342,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
             D3D9 Overlay: Not Supported
                  DXVA-HD: Not Supported
             DDraw Status: Enabled
               D3D Status: Enabled
               AGP Status: Enabled
      Sound Devices
                  Description: Kaiuttimet (SoundMAX Integrated Digital HD Audio)
      Default Sound Playback: Yes
      Default Voice Playback: Yes
                  Hardware ID: HDAUDIO\FUNC_01&VEN_11D4&DEV_989B&SUBSYS_10438372&REV_1003
              Manufacturer ID: 1
                   Product ID: 100
                         Type: WDM
                  Driver Name: ADIHdAud.sys
               Driver Version: 6.10.0002.6585 (English)
                  WHQL Logo'd: Yes
                Date and Size: 6/5/2009 11:42:04, 475136 bytes
                  Other Files:
              Driver Provider: AnalogDevices
               HW Accel Level: Basic
                    Cap Flags: 0xF1F
          Min/Max Sample Rate: 100, 200000
      Static/Strm HW Mix Bufs: 1, 0
      Static/Strm HW 3D Bufs: 0, 0
                    HW Memory: 0
             Voice Management: No
      EAX(tm) 2.0 Listen/Src: No, No
         I3DL2(tm) Listen/Src: No, No
      Sensaura(tm) ZoomFX(tm): No
                  Description: SPDIF-liitäntä (SoundMAX Integrated Digital HD Audio)
      Default Sound Playback: No
      Default Voice Playback: No
              Manufacturer ID: 1
                   Product ID: 100
                         Type: WDM
                  WHQL Logo'd: Yes
                  Other Files:
                    Cap Flags: 0xF1F
                    HW Memory: 0
                  Description: Digitaalinen lähtö (SoundMAX Integrated Digital HD Audio)
              Manufacturer ID: 1
                   Product ID: 100
                         Type: WDM
                  WHQL Logo'd: Yes
                  Other Files:
                    Cap Flags: 0xF1F
                    HW Memory: 0
      Sound Capture Devices
                  Description: Mikrofoni (SoundMAX Integrated Digital HD Audio)
        Default Sound Capture: Yes
        Default Voice Capture: Yes
                    Cap Flags: 0x1
                 Format Flags: 0xFFFFF
                  Description: Linjatulo (SoundMAX Integrated Digital HD Audio)
        Default Sound Capture: No
        Default Voice Capture: No
                    Cap Flags: 0x1
      DirectInput Devices
            Device Name: Hiiri
               Attached: 1
          Controller ID: n/a
      Vendor/Product ID: n/a
              FF Driver: n/a
            Device Name: Näppäimistö
               Attached: 1
          Controller ID: n/a
              FF Driver: n/a
            Device Name: MTE-450
               Attached: 1
          Controller ID: 0x0
      Vendor/Product ID: 0x056A, 0x0065
              FF Driver: n/a
            Device Name: HID-compliant consumer control device
               Attached: 1
          Controller ID: 0x0
      Vendor/Product ID: 0x1267, 0x0103
              FF Driver: n/a
            Device Name: HID-yhteensopiva laite
               Attached: 1
          Controller ID: 0x0
              FF Driver: n/a
      Poll w/ Interrupt: No
      USB Devices
      + USB-pääkeskitin
      | Vendor/Product ID: 0x8086, 0x3A36
      | Matching Device ID: usb\root_hub
      | Service: usbhub
      | Driver: usbhub.sys, 7/14/2009 02:07:09, 343040 bytes
      | Driver: usbd.sys, 7/14/2009 02:06:23, 7936 bytes
      Gameport Devices
      PS/2 Devices
      + HID Keyboard Device
      | Matching Device ID: hid_device_system_keyboard
      | Service: kbdhid
      | Driver: kbdhid.sys, 7/14/2009 02:00:20, 33280 bytes
      | Driver: kbdclass.sys, 7/14/2009 03:48:04, 50768 bytes
      + Terminal Server Keyboard Driver
      | Matching Device ID: root\rdp_kbd
      | Upper Filters: kbdclass
      | Service: TermDD
      | Driver: i8042prt.sys, 7/14/2009 01:19:57, 105472 bytes
      | Vendor/Product ID: 0x045E, 0x00E1
      | Matching Device ID: hid_device_system_mouse
      | Service: mouhid
      + HID-yhteensopiva hiiri
      | Service: mouhid
      | Driver: mouhid.sys, 7/14/2009 02:00:20, 31232 bytes
      | Driver: mouclass.sys, 7/14/2009 03:48:27, 49216 bytes
      + Terminal Server Mouse Driver
      | Matching Device ID: root\rdp_mou
      | Upper Filters: mouclass
      | Service: TermDD
      | Driver: termdd.sys, 7/14/2009 03:45:55, 62544 bytes
      | Driver: sermouse.sys, 7/14/2009 02:00:20, 26624 bytes
      Disk & DVD/CD-ROM Drives
            Drive: C:
      Free Space: 219.6 GB
      Total Space: 286.2 GB
      File System: NTFS
            Model: WDC WD3000HLFS-01G6U0 ATA Device
            Drive: E:
      Free Space: 224.0 GB
      Total Space: 953.8 GB
      File System: NTFS
            Model: ST31000528AS ATA Device
            Drive: D:
            Model: HL-DT-ST BD-RE  BH08LS20 ATA Device
           Driver: c:\windows\system32\drivers\cdrom.sys, 6.01.7600.16385 (Finnish), 7/14/2009 01:19:54, 147456 bytes
      System Devices
           Name: Intel(R) ICH10 Family USB Enhanced Host Controller - 3A3A
      Device ID: PCI\VEN_8086&DEV_3A3A&SUBSYS_82D41043&REV_00\3&11583659&0&EF
         Driver: C:\Windows\system32\drivers\usbehci.sys, 6.01.7600.16385 (English), 7/14/2009 02:06:30, 51200 bytes
         Driver: C:\Windows\system32\drivers\usbport.sys, 6.01.7600.16385 (Finnish), 7/14/2009 02:06:31, 324608 bytes
         Driver: C:\Windows\system32\drivers\usbhub.sys, 6.01.7600.16385 (Finnish), 7/14/2009 02:07:09, 343040 bytes
           Name: Intel(R) ICH10 Family 2 port Serial ATA Storage Controller 2 - 3A26
      Device ID: PCI\VEN_8086&DEV_3A26&SUBSYS_82D41043&REV_00\3&11583659&0&FD
         Driver: C:\Windows\system32\DRIVERS\pciide.sys, 6.01.7600.16385 (English), 7/14/2009 03:45:45, 12352 bytes
         Driver: C:\Windows\system32\DRIVERS\pciidex.sys, 6.01.7600.16385 (Finnish), 7/14/2009 03:45:46, 48720 bytes
         Driver: C:\Windows\system32\DRIVERS\atapi.sys, 6.01.7600.16385 (English), 7/14/2009 03:52:21, 24128 bytes
         Driver: C:\Windows\system32\DRIVERS\ataport.sys, 6.01.7600.16385 (Finnish), 7/14/2009 03:52:21, 155728 bytes
           Name: Intel(R) 5520/5500/X58 I/O Hub PCI Express Root Port 3 - 340A
      Device ID: PCI\VEN_8086&DEV_340A&SUBSYS_836B1043&REV_12\3&11583659&0&18
         Driver: C:\Windows\system32\DRIVERS\pci.sys, 6.01.7600.16385 (Finnish), 7/14/2009 03:45:45, 183872 bytes
           Name: Intel(R) ICH10 Family USB Universal Host Controller - 3A39
      Device ID: PCI\VEN_8086&DEV_3A39&SUBSYS_82D41043&REV_00\3&11583659&0&D2
         Driver: C:\Windows\system32\drivers\usbuhci.sys, 6.01.7600.16385 (English), 7/14/2009 02:06:27, 30720 bytes
           Name: Intel(R) ICH10 Family 4 port Serial ATA Storage Controller 1 - 3A20
      Device ID: PCI\VEN_8086&DEV_3A20&SUBSYS_82D41043&REV_00\3&11583659&0&FA
           Name: Intel(R) 5520/5500/X58 I/O Hub PCI Express Root Port 1 - 3408
      Device ID: PCI\VEN_8086&DEV_3408&SUBSYS_836B1043&REV_12\3&11583659&0&08
           Name: High Definition Audio -ohjain
      Device ID: PCI\VEN_1002&DEV_AA30&SUBSYS_AA301787&REV_00\4&2EB3824&0&0118
         Driver: C:\Windows\system32\DRIVERS\hdaudbus.sys, 6.01.7600.16385 (Finnish), 7/14/2009 02:06:13, 122368 bytes
           Name: Intel(R) ICH10 Family PCI Express Root Port 6 - 3A4A
      Device ID: PCI\VEN_8086&DEV_3A4A&SUBSYS_82EA1043&REV_00\3&11583659&0&E5
           Name: Intel(R) ICH10 Family USB Universal Host Controller - 3A38
      Device ID: PCI\VEN_8086&DEV_3A38&SUBSYS_82D41043&REV_00\3&11583659&0&D1
           Name: Intel(R) ICH10R LPC Interface Controller - 3A16
      Device ID: PCI\VEN_8086&DEV_3A16&SUBSYS_82D41043&REV_00\3&11583659&0&F8
         Driver: C:\Windows\system32\DRIVERS\msisadrv.sys, 6.01.7600.16385 (English), 7/14/2009 03:48:27, 15424 bytes
           Name: Intel(R) 5520/5500/X58 I/O Hub to ESI Port - 3405
      Device ID: PCI\VEN_8086&DEV_3405&SUBSYS_836B1043&REV_12\3&11583659&0&00
         Driver: n/a
           Name: ATI Radeon HD 4800 Series
      Device ID: PCI\VEN_1002&DEV_9440&SUBSYS_22671787&REV_00\4&2EB3824&0&0018
         Driver: C:\Windows\system32\DRIVERS\atikmdag.sys, 8.01.0001.0961 (English), 9/24/2009 01:01:24, 6175744 bytes
         Driver: C:\Windows\system32\DRIVERS\ati2erec.dll, 1.00.0000.0019 (English), 9/23/2009 23:21:08, 53248 bytes
         Driver: C:\Windows\system32\atiumd64.dll, 8.14.0010.0700 (English), 9/24/2009 00:00:58, 4649472 bytes
         Driver: C:\Windows\system32\atiumd6a.dll, 8.14.0010.0236 (English), 9/23/2009 23:54:38, 2519040 bytes
         Driver: C:\Windows\system32\atitmm64.dll, 6.14.0011.0022 (English), 9/24/2009 00:26:40, 120320 bytes
         Driver: C:\Windows\system32\atiicdxx.dat, 8/26/2009 18:58:14, 195854 bytes
         Driver: C:\Windows\system32\amdpcom64.dll, 8.14.0010.0023 (English), 9/23/2009 23:36:42, 53248 bytes
         Driver: C:\Windows\system32\atimpc64.dll, 8.14.0010.0023 (English), 9/23/2009 23:36:42, 53248 bytes
         Driver: C:\Windows\system32\atiadlxx.dll, 6.14.0010.1052 (English), 9/23/2009 23:36:12, 291840 bytes
         Driver: C:\Windows\system32\atiumd6a.cap, 9/23/2009 23:52:18, 333904 bytes
         Driver: C:\Windows\system32\atimuixx.dll, 6.14.0010.1001 (English), 9/24/2009 00:25:52, 12288 bytes
         Driver: C:\Windows\system32\atiesrxx.exe, 6.14.0011.1043 (English), 9/24/2009 00:28:02, 202752 bytes
         Driver: C:\Windows\system32\atieclxx.exe, 6.14.0011.1043 (English), 9/24/2009 00:28:36, 439296 bytes
         Driver: C:\Windows\system32\atipdl64.dll, 6.14.0010.2560 (English), 9/24/2009 00:26:20, 421376 bytes
         Driver: C:\Windows\system32\atiedu64.dll, 6.14.0010.2514 (English), 9/24/2009 00:25:46, 59392 bytes
         Driver: C:\Windows\system32\ATIDEMGX.dll, 2.00.3553.31463 (Finnish), 9/24/2009 00:28:48, 446464 bytes
         Driver: C:\Windows\system32\atio6axx.dll, 6.14.0010.9026 (English), 9/24/2009 00:17:54, 16681984 bytes
         Driver: C:\Windows\system32\aticaldd64.dll, 6.14.0010.0427 (English), 9/23/2009 23:33:06, 4592640 bytes
         Driver: C:\Windows\system32\aticalrt64.dll, 6.14.0010.0427 (English), 9/23/2009 23:33:36, 48640 bytes
         Driver: C:\Windows\system32\aticalcl64.dll, 6.14.0010.0427 (English), 9/23/2009 23:33:22, 41984 bytes
         Driver: C:\Windows\system32\atibtmon.exe, 2.00.0000.0000 (English), 5/11/2009 21:35:30, 118784 bytes
         Driver: C:\Windows\system32\atidxx64.dll, 8.17.0010.0233 (English), 9/24/2009 00:15:10, 3598848 bytes
         Driver: C:\Windows\SysWOW64\atiumdag.dll, 8.14.0010.0700 (English), 9/24/2009 00:06:42, 3593216 bytes
         Driver: C:\Windows\SysWOW64\atiumdva.dll, 8.14.0010.0236 (English), 9/23/2009 23:48:48, 2849792 bytes
         Driver: C:\Windows\SysWOW64\amdpcom32.dll, 8.14.0010.0023 (English), 9/23/2009 23:36:36, 52224 bytes
         Driver: C:\Windows\SysWOW64\atimpc32.dll, 8.14.0010.0023 (English), 9/23/2009 23:36:36, 52224 bytes
         Driver: C:\Windows\SysWOW64\atiadlxy.dll, 6.14.0010.1052 (English), 9/23/2009 23:36:04, 204800 bytes
         Driver: C:\Windows\SysWOW64\atiumdva.cap, 9/23/2009 23:48:28, 333904 bytes
         Driver: C:\Windows\SysWOW64\atipdlxx.dll, 6.14.0010.2560 (English), 9/24/2009 00:26:12, 356352 bytes
         Driver: C:\Windows\SysWOW64\Oemdspif.dll, 6.15.0006.0006 (English), 9/24/2009 00:25:58, 274432 bytes
         Driver: C:\Windows\SysWOW64\ati2edxx.dll, 6.14.0010.2514 (English), 9/24/2009 00:25:42, 43520 bytes
         Driver: C:\Windows\SysWOW64\atioglxx.dll, 6.14.0010.9026 (English), 9/23/2009 23:55:32, 12603904 bytes
         Driver: C:\Windows\SysWOW64\atidxx32.dll, 8.17.0010.0233 (English), 9/24/2009 00:22:54, 3009536 bytes
         Driver: C:\Windows\SysWOW64\aticaldd.dll, 6.14.0010.0427 (English), 9/23/2009 23:32:10, 3502080 bytes
         Driver: C:\Windows\SysWOW64\aticalrt.dll, 6.14.0010.0427 (English), 9/23/2009 23:33:34, 53248 bytes
         Driver: C:\Windows\SysWOW64\aticalcl.dll, 6.14.0010.0427 (English), 9/23/2009 23:33:20, 53248 bytes
         Driver: C:\Windows\atiogl.xml, 8/7/2009 09:31:36, 18618 bytes
         Driver: C:\Windows\system32\ATIODCLI.exe, 1.00.0000.0001 (English), 2/3/2009 20:52:08, 51200 bytes
         Driver: C:\Windows\system32\ATIODE.exe, 1.00.0000.0001 (English), 2/18/2009 17:55:24, 332288 bytes
           Name: Intel(R) ICH10 Family PCI Express Root Port 5 - 3A48
      Device ID: PCI\VEN_8086&DEV_3A48&SUBSYS_82EA1043&REV_00\3&11583659&0&E4
           Name: Intel(R) ICH10 Family USB Universal Host Controller - 3A37
      Device ID: PCI\VEN_8086&DEV_3A37&SUBSYS_82D41043&REV_00\3&11583659&0&D0
           Name: Intel(R) 5520/5500/X58 I/O Hub Throttle Registers - 3438
      Device ID: PCI\VEN_8086&DEV_3438&SUBSYS_00000000&REV_12\3&11583659&0&A3
         Driver: n/a
           Name: Intel(R) 82801 PCI Bridge - 244E
      Device ID: PCI\VEN_8086&DEV_244E&SUBSYS_82D41043&REV_90\3&11583659&0&F0
           Name: Intel(R) ICH10 Family PCI Express Root Port 3 - 3A44
      Device ID: PCI\VEN_8086&DEV_3A44&SUBSYS_82EA1043&REV_00\3&11583659&0&E2
           Name: Intel(R) ICH10 Family USB Universal Host Controller - 3A36
      Device ID: PCI\VEN_8086&DEV_3A36&SUBSYS_82D41043&REV_00\3&11583659&0&EA
           Name: Intel(R) 5520/5500/X58 I/O Hub System Management Registers - 342E
      Device ID: PCI\VEN_8086&DEV_342E&SUBSYS_00000000&REV_12\3&11583659&0&A0
         Driver: n/a
           Name: Marvell 61xx RAID Controller
      Device ID: PCI\VEN_11AB&DEV_6121&SUBSYS_82121043&REV_B2\4&28714A0B&0&00E4
         Driver: n/a
           Name: Intel(R) ICH10 Family PCI Express Root Port 1 - 3A40
      Device ID: PCI\VEN_8086&DEV_3A40&SUBSYS_82EA1043&REV_00\3&11583659&0&E0
           Name: Intel(R) ICH10 Family USB Universal Host Controller - 3A35
      Device ID: PCI\VEN_8086&DEV_3A35&SUBSYS_82D41043&REV_00\3&11583659&0&E9
           Name: Intel(R) 5520/5500/X58 I/O Hub Control Status and RAS Registers - 3423
      Device ID: PCI\VEN_8086&DEV_3423&SUBSYS_00000000&REV_12\3&11583659&0&A2
         Driver: n/a
           Name: Marvell Yukon 88E8056 PCI-E Gigabit Ethernet Controller
      Device ID: PCI\VEN_11AB&DEV_4364&SUBSYS_81F81043&REV_12\4&B1C1760&0&00E5
         Driver: C:\Windows\system32\DRIVERS\yk62x64.sys, 11.22.0003.0003 (English), 9/28/2009 09:22:00, 395264 bytes
         Driver: C:\Windows\system32\yk62x64.dll, 11.10.0002.0003 (English), 9/28/2009 09:22:00, 496128 bytes
      Device ID: PCI\VEN_8086&DEV_3A3E&SUBSYS_82EA1043&REV_00\3&11583659&0&D8
           Name: Intel(R) ICH10 Family USB Universal Host Controller - 3A34
      Device ID: PCI\VEN_8086&DEV_3A34&SUBSYS_82D41043&REV_00\3&11583659&0&E8
           Name: Intel(R) 5520/5500/X58 I/O Hub GPIO and Scratch Pad Registers - 3422
      Device ID: PCI\VEN_8086&DEV_3422&SUBSYS_00000000&REV_12\3&11583659&0&A1
         Driver: n/a
           Name: Marvell Yukon 88E8056 PCI-E Gigabit Ethernet Controller #2
      Device ID: PCI\VEN_11AB&DEV_4364&SUBSYS_81F81043&REV_12\4&325840BC&0&00E2
           Name: Intel(R) ICH10 Family USB Enhanced Host Controller - 3A3C
      Device ID: PCI\VEN_8086&DEV_3A3C&SUBSYS_82D41043&REV_00\3&11583659&0&D7
           Name: Intel(R) ICH10 Family SMBus Controller - 3A30
      Device ID: PCI\VEN_8086&DEV_3A30&SUBSYS_82D41043&REV_00\3&11583659&0&FB
         Driver: n/a
           Name: Intel(R) 5520/5500/X58 I/O Hub PCI Express Root Port 7 - 340E
      Device ID: PCI\VEN_8086&DEV_340E&SUBSYS_836B1043&REV_12\3&11583659&0&38
           Name: VIA 1394 OHCI -yhteensopiva isäntäohjain
      Device ID: PCI\VEN_1106&DEV_3044&SUBSYS_81FE1043&REV_C0\4&1B359D48&0&10F0
         Driver: C:\Windows\system32\DRIVERS\1394ohci.sys, 6.01.7600.16385 (Finnish), 7/14/2009 02:07:13, 227840 bytes
      DirectShow Filters
      DirectShow Filters:
      WMAudio Decoder DMO,0x00800800,1,1,WMADMOD.DLL,6.01.7600.16385
      WMAPro over S/PDIF DMO,0x00600800,1,1,WMADMOD.DLL,6.01.7600.16385
      WMSpeech Decoder DMO,0x00600800,1,1,WMSPDMOD.DLL,6.01.7600.16385
      MP3 Decoder DMO,0x00600800,1,1,mp3dmod.dll,6.01.7600.16385
      Mpeg4s Decoder DMO,0x00800001,1,1,mp4sdecd.dll,6.01.7600.16385
      WMV Screen decoder DMO,0x00600800,1,1,wmvsdecd.dll,6.01.7600.16385
      WMVideo Decoder DMO,0x00800001,1,1,wmvdecod.dll,6.01.7600.16385
      Mpeg43 Decoder DMO,0x00800001,1,1,mp43decd.dll,6.01.7600.16385
      Mpeg4 Decoder DMO,0x00800001,1,1,mpg4decd.dll,6.01.7600.16385
      ffdshow Video Decoder,0xff800001,2,1,ffdshow.ax,1.00.0007.3094
      ffdshow raw video filter,0x00200000,2,1,ffdshow.ax,1.00.0007.3094
      ffdshow Audio Decoder,0x3fffffff,1,1,ffdshow.ax,1.00.0007.3094
      DV Muxer,0x00400000,0,0,qdv.dll,6.06.7600.16385
      MPC - Mpeg Source (Gabest),0x00400000,0,0,MpegSplitter.ax,1.03.1290.0000
      Color Space Converter,0x00400001,1,1,quartz.dll,6.06.7600.16385
      WM ASF Reader,0x00400000,0,0,qasf.dll,12.00.7600.16385
      Screen Capture filter,0x00200000,0,1,wmpsrcwp.dll,12.00.7600.16385
      AVI Splitter,0x00600000,1,1,quartz.dll,6.06.7600.16385
      VGA 16 Color Ditherer,0x00400000,1,1,quartz.dll,6.06.7600.16385
      SBE2MediaTypeProfile,0x00200000,0,0,sbe.dll,6.06.7600.16385
      Microsoft DTV-DVD Video Decoder,0x005fffff,2,4,msmpeg2vdec.dll,6.01.7140.0000
      MPC - RealVideo Decoder,0x00600000,1,1,RealMediaSplitter.ax,1.03.1290.0000
      AC3 Parser Filter,0x00600000,1,1,mpg2splt.ax,6.06.7600.16385
      StreamBufferSink,0x00200000,0,0,sbe.dll,6.06.7600.16385
      Microsoft TV Captions Decoder,0x00200001,1,0,MSTVCapn.dll,6.01.7600.16385
      MJPEG Decompressor,0x00600000,1,1,quartz.dll,6.06.7600.16385
      CBVA DMO wrapper filter,0x00200000,1,1,cbva.dll,6.01.7600.16385
      MPEG-I Stream Splitter,0x00600000,1,2,quartz.dll,6.06.7600.16385
      SAMI (CC) Parser,0x00400000,1,1,quartz.dll,6.06.7600.16385
      VBI Codec,0x00600000,1,4,VBICodec.ax,6.06.7600.16385
      MPEG-2 Splitter,0x005fffff,1,0,mpg2splt.ax,6.06.7600.16385
      MPC - MP4 Source,0x00600000,0,0,MP4Splitter.ax,1.03.1290.0000
      Closed Captions Analysis Filter,0x00200000,2,5,cca.dll,6.06.7600.16385
      SBE2FileScan,0x00200000,0,0,sbe.dll,6.06.7600.16385
      Microsoft MPEG-2 Video Encoder,0x00200000,1,1,msmpeg2enc.dll,6.01.7600.16385
      MPC - FLV Splitter (Gabest),0x00600000,1,1,FLVSplitter.ax,1.03.1290.0000
      Internal Script Command Renderer,0x00800001,1,0,quartz.dll,6.06.7600.16385
      MPEG Audio Decoder,0x03680001,1,1,quartz.dll,6.06.7600.16385
      DV Splitter,0x00600000,1,2,qdv.dll,6.06.7600.16385
      Video Mixing Renderer 9,0x00200000,1,0,quartz.dll,6.06.7600.16385
      Haali Media Splitter,0x00800001,0,1,splitter.x64.ax,1.09.0063.0013
      Haali Media Splitter (AR),0x00400000,1,1,splitter.x64.ax,1.09.0063.0013
      Microsoft MPEG-2 Encoder,0x00200000,2,1,msmpeg2enc.dll,6.01.7600.16385
      MPC - MP4 Splitter,0x00600000,1,1,MP4Splitter.ax,1.03.1290.0000
      ACM Wrapper,0x00600000,1,1,quartz.dll,6.06.7600.16385
      Video Renderer,0x00800001,1,0,quartz.dll,6.06.7600.16385
      MPEG-2 Video Stream Analyzer,0x00200000,0,0,sbe.dll,6.06.7600.16385
      Line 21 Decoder,0x00600000,1,1,,
      Video Port Manager,0x00600000,2,1,quartz.dll,6.06.7600.16385
      Video Renderer,0x00400000,1,0,quartz.dll,6.06.7600.16385
      MPC - RealMedia Source,0x00600000,0,0,RealMediaSplitter.ax,1.03.1290.0000
      VPS Decoder,0x00200000,0,0,WSTPager.ax,6.06.7600.16385
      WM ASF Writer,0x00400000,0,0,qasf.dll,12.00.7600.16385
      VBI Surface Allocator,0x00600000,1,1,vbisurf.ax,6.01.7600.16385
      File writer,0x00200000,1,0,qcap.dll,6.06.7600.16385
      iTV Data Sink,0x00600000,1,0,itvdata.dll,6.06.7600.16385
      iTV Data Capture filter,0x00600000,1,1,itvdata.dll,6.06.7600.16385
      Haali Simple Media Splitter,0x00200000,0,1,splitter.x64.ax,1.09.0063.0013
      DirectVobSub,0x00200000,2,1,vsfilter.dll,1.00.0001.0003
      MPC - RealAudio Decoder,0x00600000,1,1,RealMediaSplitter.ax,1.03.1290.0000
      DirectVobSub (auto-loading version),0x00800002,2,1,vsfilter.dll,1.00.0001.0003
      DVD Navigator,0x00200000,0,3,qdvd.dll,6.06.7600.16385
      Microsoft TV Subtitles Decoder,0x00200001,1,0,MSTVCapn.dll,6.01.7600.16385
      Overlay Mixer2,0x00200000,1,1,,
      Haali Matroska Muxer,0x00200000,1,0,splitter.x64.ax,1.09.0063.0013
      RDP DShow Redirection Filter,0xffffffff,1,0,DShowRdpFilter.dll,
      Microsoft MPEG-2 Audio Encoder,0x00200000,1,1,msmpeg2enc.dll,6.01.7600.16385
      WST Pager,0x00200000,1,1,WSTPager.ax,6.06.7600.16385
      MPEG-2 Demultiplexer,0x00600000,1,1,mpg2splt.ax,6.06.7600.16385
      DV Video Decoder,0x00800000,1,1,qdv.dll,6.06.7600.16385
      ffdshow Audio Processor,0x00200000,1,1,ffdshow.ax,1.00.0007.3094
      SampleGrabber,0x00200000,1,1,qedit.dll,6.06.7600.16385
      Null Renderer,0x00200000,1,0,qedit.dll,6.06.7600.16385
      MPEG-2 Sections and Tables,0x005fffff,1,0,Mpeg2Data.ax,6.06.7600.16385
      Microsoft AC3 Encoder,0x00200000,1,1,msac3enc.dll,6.01.7600.16385
      MPC - FLV Source (Gabest),0x00600000,0,0,FLVSplitter.ax,1.03.1290.0000
      StreamBufferSource,0x00200000,0,0,sbe.dll,6.06.7600.16385
      Smart Tee,0x00200000,1,2,qcap.dll,6.06.7600.16385
      Overlay Mixer,0x00200000,0,0,,
      AVI Decompressor,0x00600000,1,1,quartz.dll,6.06.7600.16385
      NetBridge,0x00200000,2,0,netbridge.dll,6.01.7600.16385
      AVI/WAV File Source,0x00400000,0,2,quartz.dll,6.06.7600.16385
      MPC - MPEG4 Video Splitter,0x00600000,1,1,MP4Splitter.ax,1.03.1290.0000
      Wave Parser,0x00400000,1,1,quartz.dll,6.06.7600.16385
      MIDI Parser,0x00400000,1,1,quartz.dll,6.06.7600.16385
      Multi-file Parser,0x00400000,1,1,quartz.dll,6.06.7600.16385
      File stream renderer,0x00400000,1,1,quartz.dll,6.06.7600.16385
      ffdshow subtitles filter,0x00200000,2,1,ffdshow.ax,1.00.0007.3094
      MPC - Mpeg Splitter (Gabest),0x00400001,1,1,MpegSplitter.ax,1.03.1290.0000
      Microsoft DTV-DVD Audio Decoder,0x005fffff,1,1,msmpeg2adec.dll,6.01.7140.0000
      MPC - RealMedia Splitter,0x00600000,1,1,RealMediaSplitter.ax,1.03.1290.0000
      StreamBufferSink2,0x00200000,0,0,sbe.dll,6.06.7600.16385
      AVI Mux,0x00200000,1,0,qcap.dll,6.06.7600.16385
      MPC - MPEG4 Video Source,0x00600000,0,0,MP4Splitter.ax,1.03.1290.0000
      Line 21 Decoder 2,0x00600002,1,1,quartz.dll,6.06.7600.16385
      File Source (Async.),0x00400000,0,1,quartz.dll,6.06.7600.16385
      File Source (URL),0x00400000,0,1,quartz.dll,6.06.7600.16385
      Media Center Extender Encryption Filter,0x00200000,2,2,Mcx2Filter.dll,6.01.7600.16385
      AudioRecorder WAV Dest,0x00200000,0,0,WavDest.dll,
      AudioRecorder Wave Form,0x00200000,0,0,WavDest.dll,
      SoundRecorder Null Renderer,0x00200000,0,0,WavDest.dll,
      Haali Video Sink,0x00200000,1,0,splitter.x64.ax,1.09.0063.0013
      AC3File,0x00600000,0,1,ac3file64.ax,
      Infinite Pin Tee Filter,0x00200000,1,1,qcap.dll,6.06.7600.16385
      Enhanced Video Renderer,0x00200000,1,0,evr.dll,6.01.7600.16385
      BDA MPEG2 Transport Information Filter,0x00200000,2,0,psisrndr.ax,6.06.7600.16385
      MPEG Video Decoder,0x40000001,1,1,quartz.dll,6.06.7600.16385
      WDM Streaming Tee/Splitter Devices:
      Tee/Sink-to-Sink -muunnin,0x00200000,1,1,ksproxy.ax,6.01.7600.16385
      Video Compressors:
      WMVideo8 Encoder DMO,0x00600800,1,1,wmvxencd.dll,6.01.7600.16385
      WMVideo9 Encoder DMO,0x00600800,1,1,wmvencod.dll,6.01.7600.16385
      MSScreen 9 encoder DMO,0x00600800,1,1,wmvsencd.dll,6.01.7600.16385
      DV Video Encoder,0x00200000,0,0,qdv.dll,6.06.7600.16385
      ffdshow video encoder,0x00100000,1,1,ffdshow.ax,1.00.0007.3094
      MJPEG Compressor,0x00200000,0,0,quartz.dll,6.06.7600.16385
      Audio Compressors:
      WM Speech Encoder DMO,0x00600800,1,1,WMSPDMOE.DLL,6.01.7600.16385
      WMAudio Encoder DMO,0x00600800,1,1,WMADMOE.DLL,6.01.7600.16385
      IMA ADPCM,0x00200000,1,1,quartz.dll,6.06.7600.16385
      Microsoft ADPCM,0x00200000,1,1,quartz.dll,6.06.7600.16385
      GSM 6.10,0x00200000,1,1,quartz.dll,6.06.7600.16385
      CCITT A-Law,0x00200000,1,1,quartz.dll,6.06.7600.16385
      CCITT u-Law,0x00200000,1,1,quartz.dll,6.06.7600.16385
      MPEG Layer-3,0x00200000,1,1,quartz.dll,6.06.7600.16385
      Audio Capture Sources:
      Mikrofoni (SoundMAX Integrated ,0x00200000,0,0,qcap.dll,6.06.7600.16385
      Linjatulo (SoundMAX Integrated ,0x00200000,0,0,qcap.dll,6.06.7600.16385
      PBDA CP Filters:
      PBDA DTFilter,0x00600000,1,1,CPFilters.dll,6.06.7600.16385
      PBDA ETFilter,0x00200000,0,0,CPFilters.dll,6.06.7600.16385
      PBDA PTFilter,0x00200000,0,0,CPFilters.dll,6.06.7600.16385
      Midi Renderers:
      Default MidiOut Device,0x00800000,1,0,quartz.dll,6.06.7600.16385
      Microsoft GS Wavetable Synth,0x00200000,1,0,quartz.dll,6.06.7600.16385
      WDM Streaming Capture Devices:
      ,0x00000000,0,0,,
      SoundMAX HD Audio I,0x00200000,1,1,ksproxy.ax,6.01.7600.16385
      WDM Streaming Rendering Devices:
      ATI HD Audio rear output,0x00200000,1,1,ksproxy.ax,6.01.7600.16385
      HD Audio digital out,0x00200000,1,1,ksproxy.ax,6.01.7600.16385
      HD Audio digital out 2,0x00200000,1,1,ksproxy.ax,6.01.7600.16385
      SoundMAX HD Audio O,0x00200000,1,1,ksproxy.ax,6.01.7600.16385
      BDA Network Providers:
      Microsoft ATSC Network Provider,0x00200000,0,1,MSDvbNP.ax,6.06.7600.16385
      Microsoft DVBC Network Provider,0x00200000,0,1,MSDvbNP.ax,6.06.7600.16385
      Microsoft DVBS Network Provider,0x00200000,0,1,MSDvbNP.ax,6.06.7600.16385
      Microsoft DVBT Network Provider,0x00200000,0,1,MSDvbNP.ax,6.06.7600.16385
      Microsoft Network Provider,0x00200000,0,1,MSNP.ax,6.06.7600.16385
      Multi-Instance Capable VBI Codecs:
      BDA Transport Information Renderers:
      BDA MPEG2 Transport Information Filter,0x00600000,2,0,psisrndr.ax,6.06.7600.16385
      MPEG-2 Sections and Tables,0x00600000,1,0,Mpeg2Data.ax,6.06.7600.16385
      BDA CP/CA Filters:
      Decrypt/Tag,0x00600000,1,1,EncDec.dll,6.06.7600.16385
      Encrypt/Tag,0x00200000,0,0,EncDec.dll,6.06.7600.16385
      PTFilter,0x00200000,0,0,EncDec.dll,6.06.7600.16385
      XDS Codec,0x00200000,0,0,EncDec.dll,6.06.7600.16385
      WDM Streaming Communication Transforms:
      Audio Renderers:
      Kaiuttimet (SoundMAX Integrated,0x00200000,1,0,quartz.dll,6.06.7600.16385
      Default DirectSound Device,0x00800000,1,0,quartz.dll,6.06.7600.16385
      Default WaveOut Device,0x00200000,1,0,quartz.dll,6.06.7600.16385
      Digitaalinen lähtö (SoundMAX In,0x00200000,1,0,quartz.dll,6.06.7600.16385
      DirectSound: Digitaalinen lähtö (SoundMAX Integrated Digital HD Audio),0x00200000,1,0,quartz.dll,6.06.7600.16385
      DirectSound: Kaiuttimet (SoundMAX Integrated Digital HD Audio),0x00200000,1,0,quartz.dll,6.06.7600.16385
      DirectSound: SPDIF-liitäntä (SoundMAX Integrated Digital HD Audio),0x00200000,1,0,quartz.dll,6.06.7600.16385
      SPDIF-liitäntä (SoundMAX Integr,0x00200000,1,0,quartz.dll,6.06.7600.16385
      EVR Power Information
      Current Setting: {5C67A112-A4C9-483F-B4A7-1D473BECAFDC} (Quality)
        Quality Flags: 2576
          Enabled:
          Force throttling
          Allow half deinterlace
          Allow scaling
          Decode Power Usage: 100
        Balanced Flags: 1424
          Enabled:
          Force throttling
          Allow batching
          Force half deinterlace
          Force scaling
          Decode Power Usage: 50
        PowerFlags: 1424
          Enabled:
          Force throttling
          Allow batching
          Force scaling
          Decode Power Usage: 0
      I also ad (attach file) result from Performance Test in jpg-format.
      Sami Malmberg
        • 1. Re: Still weird problems with CS4/My new computer
          Harm Millaard Level 7
          Sami,
          The errors you get like Bad_Pool-Header, Bad-Pool_Caller etc. indicate severe driver/hardware problems. Go for a clean install. Also because your C drive contains a lot of stuff that should not be on a clean machine. You currently have around 67 GB of programs and data on you C drive. On a clean machine, even with the full Master Collection installed, plus some additional stuff, 30 GB should be enough. You have double that amount of storage in use. Additionally, your E drive is pretty full. That is what disks are for, but does that make sense to you?
          Your pagefile is not properly set. Set it to a fixed size on your fastest disk, make the min and max size around 8 GB.
          • 2. Re: Still weird problems with CS4/My new computer
            Same-eYes Level 1
            Thanks for tips!
            We may have to clear up the hole computer. I have quite a lot videomaterial in hard-drive D, waiting for edit. In C there are basic brograms, Corel X4 and some players. Nothing bigger. Still, before that, now that "normal" HD editing is working quite well,  I wonder:
            • Are CPU about  40% and Memory 4Gb values normal when I´m editing with CS4?
            • Is my computer actual powerfull enough for Creative Suite CS4?
            • Why in Earth are those 2D values so lame?
            • Hard-drives are connected in SAT 3 and 4. Should they be connected in 1 & 2?
            • First hard-drive (C:) shoud be very fast, 10 000rpm but in that performance test, and also in Windows hard-drive test results shows, why?
            • Could problem be in my memory chips?
            And:
            • In DxDiag-file, why there said that in display devices: Current Mode: 1920 x 1200 (32 bit) (59Hz) ?? Should it be 64Bit be cause displaycard is 64Bit??
            So many questions and so many possibilities...
            Thank you very much and sorry all my weird question but I´m about to explode becauise of this stupid machine!!! Arg!
            Sometimes I think that it would be better live in stoneage...
            Sami Malmberg
            ps. Check out hopepages of out feature film: www.yhtakyytia.com
            • 3. Re: Still weird problems with CS4/My new computer
              Bill Gehrke Adobe Community Professional & MVP
              Try running my Premiere  Pro benchmark and see what results you get.  Email me the results and I will comment on your system and the tuning.
              Edit:  One of your questions did trigger a thought--When you switch to multicam I am sure that you will be using more memory than just HD processing.  Test you memory, there is a possiibilty that you have a high memory error that would only show up when you exceed a certain address.
              • 4. Re: Still weird problems with CS4/My new computer
                Chuck A. McIntyre Level 3
                I think there is a good chance that you have a bad stick of memory.
                Go to Control Panel - System and Security - Administrative Tools - Windows Memory Diagnostic. One of the nice features built right into Windows 7.
