3 Replies Latest reply on Nov 12, 2009 2:47 PM by [Jongware]
    Script that worked in CS does not work in CS4 - multiple open page, print , pdf export and close
    Dawid_Ruzicka
      I had a script that worked great for me in Indesign CS. But now does not work in CS4. Anyone knows what needs to be done to make it work again ?
      When I drop folder with indesign files on top of this script:
      1. opens first page
      2. turns specific layer on
      3. prints using preset
      4. exports using preset
      5. close without saving
      6. next page
      Anyone who can give me solution or idea how this should work is greatly appreciated.
      on open sourceFolders
      repeat with sourceFolder in sourceFolders
      tell application "Finder"
      try
      -- If you would like to include subfolders, you say - every file of entire contents of folder…
      set idFiles to (every file of folder sourceFolder whose file type is "IDd5") as alias list
      on error -- work around bug if there is only one file
      set idFiles to (every file of folder sourceFolder whose file type is "IDd5") as alias as list
      end try
      end tell
      if idFiles is not {} then
      tell application "Adobe InDesign CS4"
      set user interaction level to never interact
      repeat with i from 1 to count of idFiles
      open item i of idFiles
      tell document 1
      try
      set visible of layer "ImagesTag_Layer" to true
      end try
      set myPreset to "letter size" -- name of print style to use
      with timeout of 700 seconds
      print using myPreset without print dialog
      end timeout
      set myPreset1 to "pdf preset name" -- name of pdf export style to use
      set myName to the name -- name includes .indd should remove at some point
      export format PDF type to "users:temp:Desktop:pdf:" & myName & ".pdf" using myPreset1 without showing options -- set path here format ComputerName:Folder1:Folder2:......:FileName.pdf
      end timeout
      end tell
      end repeat
      set user interaction level to interact with all
      end tell
      end if
      return 10 -- try again in 10 seconds
      end repeat
      end open
