0 Replies Latest reply on Nov 12, 2009 12:58 PM by deepa subramaniam (adobe)
    [svn:fx-trunk] 11727: You can' t just assume the first shader filter in a maskee object' s filter array is the luminosity shader when rendering a luminosity mask.
    deepa subramaniam (adobe) Level 2
      Revision: 11727
      Author:   dsubrama@adobe.com
      Date:     2009-11-12 12:58:37 -0800 (Thu, 12 Nov 2009)
      Log Message:
      You can't just assume the first shader filter in a maskee object's filter array is the luminosity shader when rendering a luminosity mask. Instead, we now loop through all the filters in the array and search for the luminosity shader.
      QE notes: None
      Doc notes: None
      Bugs: SDK-24180
      Reviewer: Ryan
      Tests run: FXG runtime, FXG static
      Is noteworthy for integration: No
      Ticket Links:
          http://bugs.adobe.com/jira/browse/SDK-24180
      Modified Paths:
          flex/sdk/trunk/frameworks/projects/spark/src/spark/components/supportClasses/GroupBase.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/primitives/supportClasses/GraphicEleme nt.as
