0 Replies Latest reply on Nov 12, 2009 1:18 PM by Paul Reilly
    [svn:fx-trunk] 11732: * Another batch of compiler fixes.
    Paul Reilly Level 1
      Revision: 11732
      Author:   preilly@adobe.com
      Date:     2009-11-12 13:18:47 -0800 (Thu, 12 Nov 2009)
      Log Message:
      • Another batch of compiler fixes.
      QE notes: The mxunit test
                Namespaces_LibraryTag_Definition_GraphicalAssetTest failed,
                but I think the test should result in a compile error.
      Doc notes:
      Bugs: SDK-23898, SDK-24001, SDK-24075, SDK-22471, SDK-23772, SDK-23662
      Reviewer: Corey
      Tests run: ran full cyclone twice, but all the mustella tests timed
                 out on the "cyclone assist" server, so I ran a sampling
                 locally.
      Is noteworthy for integration: No
      Code-level description of changes:
        modules/swfutils/src/java/flash/util/StringUtils.java
          Modified unformatString() to more closely match the opposite of
          formatString() by only converting a double backslash to a single
          backslash when it precedes a 'u'.  This fixes SDK-23898.
        modules/compiler/src/java/flex2/compiler/common/CompilerConfiguration.java
          Made report-invalid-styles-as-warnings and
          show-invalid-css-property-warnings no longer hidden.  This fixes
          SDK-24001.
        modules/compiler/src/java/flex2/compiler/SymbolTable.java
          Added debug param to constructor and modified it to turn on
          perCompileData.omitTrace when it's false.  This fixes SDK-24075.
        modules/compiler/src/java/flex2/compiler/mxml/rep/AtEmbed.java
          Uncommented fix for SDK-22471, which was accidentally commented
          out.
        modules/compiler/src/java/flex2/compiler/mxml/InterfaceCompiler.java
          Modified analyze(XMLNode) to only add an import for XMLUtil when
          e4x is false.  This fixes SDK-23772.
          Modified analyze(XMLListNode) to no longer add an import for
          XMLUtil, because it's not used.
          Modified createInlineComponentUnit() and createDefinitionUnit() to
          use new method getInnerClassName() to create a unique className,
          if the user doesn't specify one.  This fixes SDK-23662.
      Ticket Links:
          http://bugs.adobe.com/jira/browse/SDK-23898
          http://bugs.adobe.com/jira/browse/SDK-24001
          http://bugs.adobe.com/jira/browse/SDK-24075
          http://bugs.adobe.com/jira/browse/SDK-22471
          http://bugs.adobe.com/jira/browse/SDK-23772
          http://bugs.adobe.com/jira/browse/SDK-23662
      Modified Paths:
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/SymbolTable.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/common/CompilerConfiguration.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/InterfaceCompiler.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/rep/AtEmbed.java
          flex/sdk/trunk/modules/swfutils/src/java/flash/util/StringUtils.java
