0 Replies Latest reply on Nov 12, 2009 2:28 PM by CoreyRLucier
    [svn:fx-trunk] 11751: Setting a transform matrix would always invalidate and cause an update.
    CoreyRLucier Adobe Employee
      Revision: 11751
      Author:   clucier@adobe.com
      Date:     2009-11-12 14:28:38 -0800 (Thu, 12 Nov 2009)
      Log Message:
      Setting a transform matrix would always invalidate and cause an update.  If you were setting a transform matrix in upateDisplayList, you'd end up in a continuous update loop.  Added logic to early exit (and not invalidate) when the newly set matrix is identical to the existing.
      QE notes: None
      Doc notes: None
      Bugs: SDK-22807
      Reviewer: Evtim
      Tests run: Checkin
      Is noteworthy for integration: No
      Ticket Links:
          http://bugs.adobe.com/jira/browse/SDK-22807
      Modified Paths:
          flex/sdk/trunk/frameworks/projects/framework/src/mx/core/UIComponent.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/utils/MatrixUtil.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/core/SpriteVisualElement.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/primitives/supportClasses/GraphicEleme nt.as
