5 Replies Latest reply on Nov 12, 2009 7:20 PM by shooternz
    Rate Stretch Tool Breaks Transparency?
    roschler
      I am using Adobe Premiere Pro 1.5.1.  I have an AVI that has Alpha Channel info.  If I import it into Premiere and place it in a sequence, and then put a video or bitmap below it, it works fine.  I can see the background track show through as expected.  However, if I use the rate stretch tool, then the clip's transparent areas change to black and I can no longer see anything behind the clip.  Does the Rate Stretch Tool do something to disrupt a clip's Alpha Channel?  Is there a way to make this work?
      Thanks.
