5 Replies Latest reply on Nov 13, 2009 10:37 AM by the_wine_snob
    Sound and video get out of sync
    robert_cfi
      I am trying to craete a small little instructional video
      My video is a .avi that has 44100 audio and 29 fps
      First - Which presets should I be using?
      Second - Im trying every preset I can and watching some videos but everytime I try and edit my video and then play or move the timeline the sound gets off.  Can you guys help? Thanks so much if you can
      Im on CS4 and have done all the Updates
        • 1. Re: Sound and video get out of sync
          the_wine_snob Level 9
          Robert,
          Welcome to the forum. Please tell us more about these .AVI files. AVI is but a "wrapper," and many different CODEC's can be enclosed. This ARTICLE will give you background, plus tell you how to find out more about those files. That info will direct you in the choice of your Project/Sequence Presets - they should match 100%.
          • 2. Re: Sound and video get out of sync
            robert_cfi Level 1
            That was great info and I love G-spot
            Says i have the codec installed
            video
            Codec is MJPG name Motion MJPG
            29.970
            audo
            codec is 0x0011 DVI ADPCM
            info : 44100hz 177kb/s [1chnl]
            size : 718 MB (735,394 KB / 753,044,132 bytes)
            Container :
            AVI v1.0
            video 713mb
            video 4mb
            avi overhead 260kb
            Im still not sure which Preset to use?  I read your article and may have just missed how to check the preset?
            • 3. Re: Sound and video get out of sync
              Harm Millaard Level 7
              You have three options:
              1. Download the Morgan MJPEG codec
              2. Download the MainConcept MJPEG codec
              3. Convert to DV AVI type2. Use Google to find a converter.
              • 4. Re: Sound and video get out of sync
                Jim_Simon Level 8
                There is a fourth option.
                Stop using 'video' from still cameras and other non-standard devices and only use DV, DVCAM, DVCPRO, DVCPRO 50, DVCPRO HD, AVC-I or R3D media.
                • 5. Re: Sound and video get out of sync
                  The selection of the Preset will depend on exactly what G-Spot tells you about your source footage. Things like Frame Size, Frame Rate, etc.
                  As for MJPEG, I agree with Harm's suggestion to install either the Morgan, or the MainConcept MJPEG CODEC's. For most users, either works perfectly. The choice is yours.
                  I wonder which MJPEG CODEC you have installed? G-Spot has Tables, where you can see installed Video CODEC's. Be aware that it will show false positives for the Adobe MainConcept installed CODEC's being broken. This is due to Adobe's naming convention for its installed CODEC's, to keep others from overwriting, or breaking them, but it fools G-Spot and Sherlock the CODEC Detective.
