5 Replies Latest reply on Nov 20, 2009 9:42 AM by taotaomono
    Installing an AIR application with PackageMaker on OS X
    taotaomono
      Hello,
      My company has signed the redistribution agreement and I've been working on building an installer using the PackageMaker application built into Mac OS X.
      I'm seeing behavior where the installer fails every other time that it is run. The output from .airappinstall.log is below.
      I've reproduced this behavior from the installer as well as by running the following command line:
      sudo /Applications/Utilities/Adobe\ AIR\ Application\ Installer.app/Contents/MacOS/Adobe\ AIR\ Application\ Installer -silent /MyApp.air
      Has anyone seen this behavior before?
      Starting silent x1 install from file:///tmp/MyApp.air
      UI SWF load is complete
      stateRunningAppInstaller: appinstaller -runtime "/tmp/Adobe AIR Installer Stand Alone.app/Contents/Frameworks" -silent -withRuntime -url file:///MyApp.air
      App installer completed successfully
      begin quitting
      App installer failed; exit code 7
      begin quitting
      Starting silent x1 install from file:///MyApp.air
      begin quitting
      begin quitting
      begin quitting
      Starting silent x1 install from file:///MyAppE.air
      begin quitting
        • 1. Re: Installing an AIR application with PackageMaker on OS X
          taotaomono Level 1
          I realize I left out some relevant information.
          After I a successful installation of the application, I remove it by either dragging it to the Trash or with AppCleaner.
          Once the application has been removed, I reinstall by running the .pkg file or from the command line that I entered in my first post.
          I suspect that the removal process is leaving something behind that is causing every other install to fail.
          I've seen errors that say that the air file is corrupt which seems to be associated with this error: failed while unpackaging: [ErrorEvent type="error" bubbles=false cancelable=false eventPhase=2 text="Error #2004" errorID=2004]
          Can anyone tell me what the error 2004 or exit code messages mean?
          • 2. Re: Installing an AIR application with PackageMaker on OS X
            taotaomono Level 1
            Can anyone tell me what exit code 7 or error code 2004 mean?
            Also, if there is another bootstrapper application that is more compatible with AIR I'd appreciate some suggestions.
            • 3. Re: Installing an AIR application with PackageMaker on OS X
              taotaomono Level 1
              Here's the output from .airinstall.log and .airappinstall.log
              machine:~ root# cat .airinstall.log
              stateRunningAppInstaller: appinstaller -runtime "/tmp/Adobe AIR Installer Stand Alone.app/Contents/Frameworks" -silent -withRuntime -url file:///tmp/MyApp.air
              begin quitting
              machine:~ root# tail .airappinstall.log
              Starting silent app install of file:///tmp/MyApp.air
              UI initialized
              Unpackaging to /private/var/folders/zz/zzzivhrRnAmviuee+++++++++++/TemporaryItems/FlashTmp0
              unpackaging is complete
              application is bound to side-by-side version 1.0
              application is bound to this version of the runtime
              app id MyApp
              pub id ---
              starting cleanup of temporary files
              application installer exiting
              • 4. Re: Installing an AIR application with PackageMaker on OS X
                Juan_G
                According to this Flex Reference document:
                http://livedocs.adobe.com/flex/3/langref/runtimeErrors.html
                #2004 is indicative of an invalid parameter being passed.
                The exit code 7 indicates that the installation failed. I would make sure that the application is not already installed. You indicate in your previous message that you remove the file by dragging it to the Trash. Make sure to the empty the Trash as well. I would also recommend checking to see what the LaunchServices Database thinks is installed. You can query this by typing the following:
                /System/Library/Frameworks/CoreServices.framework/Frameworks/LaunchServices.framework/Supp ort/lsregister -dump | grep MyApp
                It should return all instances of your application on your system. Hope this helps.
                juan
                Adobe AIR QE
                • 5. Re: Installing an AIR application with PackageMaker on OS X
                  taotaomono Level 1
                  Juan,
                  Thanks for your input, I'll give it a try.
                  Cheers,
                  Charles
