3 Replies Latest reply on Nov 13, 2009 9:47 AM by the_wine_snob
    Avi file imported to Premiere Pro CS3 changes its duration length?
    Macnimation Level 1
      I haven't seen this issue before.
      I have 7 Avi files all various lengths.
      The first 6 files all imported fine.
      The 7th Avi file is 7 min 27 sec long, and it plays fine in Windows Media Player, Quicktime player, VLC etc.
      When I import it into the Premiere Pro CS3 Project it changes to a video length of 16 sec 15 frames.
      It plays the 16 secs fine, but ends there.
      I have no idea what is causing this or how to fix it.
      Any help would be appreciated.
        • 1. Re: Avi file imported to Premiere Pro CS3 changes its duration length?
          Jeff Bellune Level 5
          What codec was used to create the AVI file?  Use the free program GSpot to find out. If it's DV type-1, then that would explain the behavior you're seeing.  You would need to convert it to DV type-2.
          -Jeff
          • 2. Re: Avi file imported to Premiere Pro CS3 changes its duration length?
            Macnimation Level 1
            thanks for the info. I had actually read th other similar threads, but was sure it might be different as 6 out of the 7 files, all encoded the same way were fine.
            It is DV type 1.
            I'll try the other option.
            cheers
            • 3. Re: Avi file imported to Premiere Pro CS3 changes its duration length?
              the_wine_snob Level 9
              I have observed similar, though with a totally different workflow. I get handed all sorts of "stuff," and have to work with it. Much gets run through my conversion program and the conversion to DV-AVI Type II is almost always perfect to work with, though with the common, resultant loss in quality from the intial encoding. Every now and then, I get one of these that will Import into PrPro with the wrong duration. It's usually pretty heavily truncated to say 04;00;00, when it should be 45;00;00. These problem files play fine in various players, and G-Spot (plus others) show the proper Duration.
              Now, I have found that if I Import the problem file into PrElements, and then just Export as a DV-AVI Type II (same settings as from the conversion program), the Duration issue is fixed. I have compared the two DV-AVI Type II's to each other, and they show as being identical. DupeFile Finder shows them as the same! Still, one will NOT Import with the proper Duration, and the other one will. To date, I have not been able to find out why. It just works.
              This workaround has been 100% successful, and I just use PrE as a tool to "fix" whatever is wrong.
              Like I said, the result is the same as yours, but the source and workflow is just different.
              Wish I could explain the why, or what is happening, but I cannot.
