8 Replies Latest reply on Jul 15, 2008 2:28 PM by Newsgroup_User
    Calling Javascript (k)
    Level 7
      I've done this(calling a Javascript function from Flash) before, but
      haven't done it in a while.
      I want to get this HTML code:
      <a href="JavaScript:void(0)" onclick="ChangeState('link1')">Link 1</a>
      to work in Flash. Here is where I am with it. I attached this
      ActionScript to a button in Flash. On the HTML page the flash file
      resides is the Javascript.
      on (release) {
      getURL("javascript:void(0)" and "ChangeState('link2')");
      Any ideas?
      -Kirk
        • 1. Re: Calling Javascript (k)
          robdillon Most Valuable Participant
          You could use:
          on (release) {
          getURL("javascript:ChangeState('link2')");
          but read through this tech note on using ExternalInterface: http://kb.adobe.com/selfservice/viewContent.do?externalId=tn_15683
          • 2. Re: Calling Javascript (k)
            Level 7
            Your version didn't work(thanks, though).
            That technote is beyond my knowledge of ActionScript. It also appears to
            want Javascript to control Flash. I need Flash to control a Javascript
            Function.
            Any other ideas?
            -kirk
            Rob Dillon wrote:
            > You could use:
            > on (release) {
            • 3. Re: Calling Javascript (k)
              Level 7
              That code should work. Any thoughts why it doesn't:
              on (release) {
              -Kirk
              > Function.
              > Any other ideas?
              > -kirk
              > Rob Dillon wrote:
              >> You could use:
              >> on (release) {
              • 4. Re: Calling Javascript (k)
                Level 7
                I just tried simpler javascript that I got right from the Adobe website:
                getURL("javascript:alert('you clicked me')");
                It doesn't work either. Any thoughts? This happens in Safari and Firefox 3
                -Kirk
                > on (release) {
                > -Kirk
                >> to want Javascript to control Flash. I need Flash to control a
                >> Javascript Function.
                >> Any other ideas?
                >> -kirk
                >> Rob Dillon wrote:
                >>> You could use:
                >>> on (release) {
                • 5. Re: Calling Javascript (k)
                  Level 7
                  After searching the web for a while I discovered that the
                  getURL("javascript: method I'd used in the past is not secure.
                  There's a new method that I don't understand at all.
                  Has anyone successfully done any Javascript connection through Flash
                  since the April 2008 security update?
                  If so, how do you do it?
                  -Kirk
                  > -Kirk
                  >> on (release) {
                  >> -Kirk
                  >>> Any other ideas?
                  >>> -kirk
                  >>> Rob Dillon wrote:
                  >>>> You could use:
                  >>>> on (release) {
                  • 6. Re: Calling Javascript (k)
                    Take a look at this example: http://www.ddg-designs.com/downloads/callJSfunction.zip. This is a very simple example using ExternalInterface.
                    • 7. Re: Calling Javascript (k)
                      Level 7
                      Thanks, I'll check it out.
                      I got it working the old way by changing:
                      'allowScriptAccess','sameDomain',
                      to
                      'allowScriptAccess','always',
                      in the HTML that pulls in the SWF.
                      Not sure what that does to my security. The only thing this Javascript
                      does is changes out a background image if a variable is true in Flash.
                      -Kirk
                      • 8. Re: Calling Javascript (k)
                        Level 7
                        It's official. I am a complete and utter moron.
                        I didn't need to change a thing. I just needed to upload it off my local
                        machine with 'sameDomain' in there as it was.
                        Absolutely stupid.
                        -Kirk
                        > to
                        > -Kirk
