5 Replies Latest reply on Jul 20, 2008 1:45 PM by tomwood2
    Naming the swap image - Can't find it in the tag inspector.
    tomwood2 Level 1
      Hello,
      I followed an online description of how to do swap images (mouse rollover) for a hyperlink. The article said that swap images work best if the images are "named" which is a different attribute than the image file name. I was able to name the first image, but I never got a window that lets me name the swap image. The rollover effect is working fine, but I want to follow best practices if the swap image should also be named.
      Where do I get the menu to name the swap image?
      Tom
        • 1. Re: Naming the swap image - Can't find it in the tag inspector.
          tomwood2 Level 1
          Forgot to mention, I'm working in Dreamweaver 8.
          TW
          • 2. Re: Naming the swap image - Can't find it in the tag inspector.
            Level 7
            Select an image. Look at the Property Inspector. There is a field called
            "Name". Use it. Or just add the "name" attribute manually -
            <img name="goober"....
            Murray --- ICQ 71997575
            Adobe Community Expert
            (If you *MUST* email me, don't LAUGH when you do so!)
            http://www.projectseven.com/go - DW FAQs, Tutorials & Resources
            http://www.dwfaq.com - DW FAQs, Tutorials & Resources
            "tomwood2" <webforumsuser@macromedia.com> wrote in message
            news:g5vivn$e9r$1@forums.macromedia.com...
            > Hello,
            > for
            > able to
            > practices
            > Thanks,
            > Tom
            • 3. Re: Naming the swap image - Can't find it in the tag inspector.
              tomwood2 Level 1
              That's the trouble, I can't figure out how to 'select' the image that is the second image. Here's the code after applying the swap image behavior:
              <img src="images/smile120x90.png" name="smile" id="smile" onmouseover="MM_swapImage('smile','','images/kiss120x90.png',1)" onmouseout="MM_swapImgRestore()" />
              I'm swapping in a kiss when the mouse hovers over a smile. After Insert>Image and inserting the first image, images/smile120x90.png, I can select it and name it 'smile'. But placing the cursor over images/kiss120x90.png inside that behavior code doesn't select that image.
              Tom
              • 4. Re: Naming the swap image - Can't find it in the tag inspector.
                Level 7
                You only have to name the trigger image. Select the trigger, apply the
                behavior, browse to and select the incoming image (by filename!), and click
                OK.
                news:g603ub$1of$1@forums.macromedia.com...
                > the
                > Insert>Image
                > name
                > Thanks,
                > Tom
                • 5. Re: Naming the swap image - Can't find it in the tag inspector.
                  tomwood2 Level 1
                  OK.
                  Okay, thanks! I just wanted to make sure I didn't miss something.
                  TW
