0 Replies Latest reply on Nov 13, 2009 11:38 AM by rfrishbe
    [svn:fx-trunk] 11789: When a UIMovieClip resizes, it does so through scaling.
    rfrishbe Level 3
      Revision: 11789
      Revision: 11789
      Author:   rfrishbe@adobe.com
      Date:     2009-11-13 11:38:40 -0800 (Fri, 13 Nov 2009)
      Log Message:
      When a UIMovieClip resizes, it does so through scaling. Before UIMC was keeping track of this on it's own.  Now that AdvancedLayoutFeatures support this through scaleX/scaleY, UIMC can now rely on this behavior.  This also helps fix some Effects bugs which rely on this to figure out the difference in transformations that get applied and contribute to the "width" and "height" properties and ones that don't.
      QE notes: Can re-include the 3 FCK tests and regen the bitmaps
      Doc notes: -
      Bugs: SDK-23754, SDK-23779
      Reviewer: Evtim
      Tests run: checkintest, mustella FCK
      Is noteworthy for integration: No
      Ticket Links:
          http://bugs.adobe.com/jira/browse/SDK-23754
          http://bugs.adobe.com/jira/browse/SDK-23779
      Modified Paths:
          flex/sdk/trunk/frameworks/projects/flash-integration/src/mx/flash/ContainerMovieClip.as
          flex/sdk/trunk/frameworks/projects/flash-integration/src/mx/flash/FlexContentHolder.as
          flex/sdk/trunk/frameworks/projects/flash-integration/src/mx/flash/UIMovieClip.as
          flex/sdk/trunk/frameworks/projects/utilities/src/MyFlexContentHolder.as
