4 Replies Latest reply on Nov 16, 2009 9:35 AM by Yozef0
    Custom SummaryFunction for AdvancedDataGrid
    Yozef0 Level 1
      I have an AdvancedDataGrid that gets populated (XML > Objects > ArrayCollection).
      The Adv. DataGrid has summary rows (of GroupCollection) that gets updated (operation = either SUM or AVG depeding on a ComboBox selection).
      One of my Columns is more tricky than a simple AVG or SUM of it's rows.
      • I am trying to Find the SUM of the Rows ( of the group) / number of Rows + 1. The AVG operation does that, but does not add 1 to the num of rows.
      So I figure a SummaryFunction is the way to go. I searched for some, and found this:
      private function operationPercentChange(cursor:IViewCursor, dataField:String, operation:String):Number {
           var sumOfValues:Number = 0;
           while (!cursor.afterLast){
                sumOfValues += cursor.current["change"]; // change is the datafield in question
                trace ("cursor.current = " + cursor.current["change"]);
                cursor.moveNext();                       // I suppose this gets the next value?
           return actualTotal;
      So the above gives me nothing, though if I explicitly return a number, it shows it to me, so I've got the function set up correctly, now all I need is getting the rows of that column and Sum them up, and divide them by the number of rows (of that group) + 1.
      Another summaryFunction would return the Value of a different column's Last Row (in that group) - First Row (in that group) / First Row (in that group) * 100
      I've attached a snapshot which is much easier to understand.
        • 1. Re: Custom SummaryFunction for AdvancedDataGrid
          msakrejda Level 4
          You update sumOfValues but return actualTotal.
          • 2. Re: Custom SummaryFunction for AdvancedDataGrid
            Yozef0 Level 1
            Oh I know the function above is wrong...
            It's getting the variables that I'm having trouble with... Especially first and last of the summary childs... The graph explains it clearly I think.
            Thanks for your help though
            • 3. Re: Custom SummaryFunction for AdvancedDataGrid
              Sameer Bhatt Adobe Employee
              Hi Joseph,
              Try these summary functions -
              private function calculateSum(cursor:IViewCursor, dataField:String, operation:String):Number
                  var sum:Number = 0;
                  var count:int = 1; // start with 1 as we need to calculate sum/(num + 1)
                      sum += cursor.current[dataField];
                      count++;
                      cursor.moveNext();
                  return sum/count;
              private function calculatePercent(cursor:IViewCursor, dataField:String, operation:String):Number
                  var firstValue:Number = cursor.current[dataField];
                  var lastValue:Number = 0;
                  // move to the last value
                      lastValue = cursor.current[dataField];
                      cursor.moveNext();
                  return (lastValue - firstValue) * 100 / firstValue;
              Note: These methods needs some edge case handling.
              • 4. Re: Custom SummaryFunction for AdvancedDataGrid
                Yozef0 Level 1
                    var firstValue:Number = cursor.current["visits"];  // needed to get the values of a different column
                        lastValue = cursor.current["visits"];
                        cursor.moveNext();
                The above worked perfectly... Thanks Sameer , and minor changes got the other function working:
                private function AVGPercentChange(cursor:IViewCursor, dataField:String, operation:String):Number {
                            var sum:Number = 0;
                            var count:int = 0;
                            while (!cursor.afterLast) {
                                sum += Number(cursor.current[dataField]);
                                count++;
                                cursor.moveNext();
                            return sum/count;     // removes the 0 valued row by reducing the num of rows
                Thanks Million Sameer
