0 Replies Latest reply on Nov 13, 2009 2:01 PM by Jason Szeto
    [svn:fx-trunk] 11798: Border bug fix
    Jason Szeto Level 3
      Revision: 11798
      Revision: 11798
      Author:   jszeto@adobe.com
      Date:     2009-11-13 14:01:46 -0800 (Fri, 13 Nov 2009)
      Log Message:
      Border bug fix
      http://bugs.adobe.com/jira/browse/SDK-23824 - Border size does not update when a child element is included after a state change
      The bug was that we were explicitly setting the width and height of the contentGroup in updateDisplayList. This meant that if content was added later, it was not forcing a resize of the contentGroup and thus the skin did not update. Using setActualSize does not work because it breaks constraints set on children. The solution is to use constraints on the contentGroup.
      QE notes: none
      Doc notes: none
      Bugs: SDK-23824
      Reviewer: Kevin
      Tests run: Border
      Is noteworthy for integration: No
      Ticket Links:
      Modified Paths:
          flex/sdk/trunk/frameworks/projects/spark/src/spark/skins/spark/BorderSkin.as
