0 Replies Latest reply on Nov 13, 2009 3:18 PM by Evtim Georgiev (Adobe)
    [svn:fx-trunk] 11803: Fix http://bugs.adobe.com/jira/browse/ SDK-24080 fxg components with RichText report the wrong bounds ( the RichText is not measured correctly)
      Revision: 11803
      Revision: 11803
      Author:   egeorgie@adobe.com
      Date:     2009-11-13 15:17:51 -0800 (Fri, 13 Nov 2009)
      Log Message:
      Fix http://bugs.adobe.com/jira/browse/SDK-24080 fxg components with RichText report the wrong bounds (the RichText is not measured correctly)
      Problem: Styles and RichText are now initialized after the construction of the SpriteVisualElement, but the SVE measures itself in its c-tor.
      Fix: when the RichText is validates, invalidate the size and re-measure the SpriteVisualElement.
      QE notes: None
      Doc notes: None
      Bugs: SDK-24080
      Reviewer: Pete, Ryan
      Tests run: None
      Is noteworthy for integration: No
      Ticket Links:
      Modified Paths:
          flex/sdk/trunk/frameworks/projects/spark/src/spark/core/SpriteVisualElement.as
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/fxg/FlexFXG2SWFTranscoder.java
