0 Replies Latest reply on Nov 13, 2009 3:37 PM by kevinklin
    [svn:fx-trunk] 11804: Fix for https://bugs.adobe.com/jira/browse/SDK-24205.
    kevinklin Adobe Employee
      Revision: 11804
      Revision: 11804
      Author:   klin@adobe.com
      Date:     2009-11-13 15:37:14 -0800 (Fri, 13 Nov 2009)
      Log Message:
      Fix for https://bugs.adobe.com/jira/browse/SDK-24205. ComboBox checked to see if the focusOut target was itself, but if the ComboBox is editable then the target is actually the TextField. I altered it to check if the target is contained by the ComboBox instead. This allows the dropDown to close if the user tabs out of the ComboBox with the dropDown open. Same fix in DateField.
      QE notes: No
      Doc notes: No
      Bugs: SDK-24205
      Reviewer: Ryan
      Tests run: checkintests
      Is noteworthy for integration: No
      Ticket Links:
          http://bugs.adobe.com/jira/browse/SDK-24205
      Modified Paths:
          flex/sdk/trunk/frameworks/projects/framework/src/mx/controls/ComboBox.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/controls/DateField.as
